Encoder CertificationAeroElectric-List: Encoder Certificatio
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
Billvt
PostPosted: Fri Jan 22, 2010 8:55 am    Post subject: Encoder CertificationAeroElectric-List: Encoder Certificatio Reply with quote
1/22/201It does not mention "Controlled Airspace" anywhere in 91.215 (b) but:91.215 (c) states:Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraftequipped with an operatble ATC transponder maintained in accordance with 91.413of this part shall operate the transponder, including Mode C equipment f installedand shall reply on the appropriated code or as assigned by ATC.***********************************************************************************************************************So this means to me that if you have a transponder installed that has been tested It does not mention "Controlled Airspace" anywhere in 91.215 (b) but:
Bill Morelli
billvt(at)together.net (billvt(at)together.net)
EarthLink Revolves Around You.
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
