Homebuilt-List Digest: 0 Msgs - 04/13/06
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Homebuilt-List
AMERIPOND(at)cs.com
PostPosted: Fri Apr 14, 2006 12:11 pm    Post subject: Homebuilt-List Digest: 0 Msgs - 04/13/06 Reply with quote
Hi All
Recently I purchased a David Clark headset H-10-76 on e-bay for use on a new
I-com a 200 and being a single plug helicopter type I also purchased a
helicopter to standard adaptor. The mic is best I can determine, the M87/a1c and
according to the I-com manual it should be compatible but I can't get an audio
signal into a scanner that I have near by. I hooked up a SWR/watt meter and it
shows a signal when I hit transmit and also on the I-comm unit it shows tx but
no responce in asking for radio checks or on the scanner...any thoughts???...
thanx Jim
- The Matronics Homebuilt-List Email Forum -
http://www.matronics.com/Navigator?Homebuilt-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Homebuilt-List All times are GMT - 8 Hours
