Where & how to run strobe light wiring?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
ideaz1(at)sbcglobal.net
PostPosted: Wed Feb 03, 2010 5:03 pm    Post subject: Where & how to run strobe light wiring? Reply with quote
I'm not started with my 750 yet, but it will be my third build. I put wires
on the main spar previously since it is closest to the balance point (yes
that's a bit anal) my other suggestion is to ty wrap only as far in as you
can reach in case you ever have to replace a wire. Also I have installed
wiring after the fact by sliding a length of 1/2" pvc tubing through the
wing, then run the wire through that till you can get hold of the other end
then pull out the tubing leaving the wire(s) behind.
Dirk Z.
Carson City, NV
I'm ready to rivet the bottom side of my trailing edge on my first wing, but
need to run wiring for the wingtip strobe. Anyone have a photo of how &
where they ran these wires? I assume they go down the trailing edge cavity
attached to the aft side of the rear spar, rather than in front of the main
spar.
Jimmy Young
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
