Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustr
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
joemotis(at)gmail.com
PostPosted: Tue Feb 09, 2010 2:34 pm    Post subject: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustr Reply with quote
One of my hangar buddies plotted it out on the computer and it works perfectly at 40 mm if the extrusion is 3/4"x3/4" instead of 1"x1"
What other mistakes has any one found on the second set of prints for the CH 750??
This was a $40 mistake and I can't even claim credit.
Joe Motis
CH 750 WW Corvair
On Sun, Feb 7, 2010 at 8:18 PM, Art Olechowski <ifly4fun2(at)sbcglobal.net (ifly4fun2(at)sbcglobal.net)> wrote:
[quote] Joe,
Great catch and likely only something a scratch builder would have caught.  I'm not as far a long as you are but I've made note to cut the upper spar cap angle using the web as the guide.  Thank you for passing along your finding.
Art
Wichita, KS
--- On Sun, 2/7/10, joe motis <joemotis(at)gmail.com (joemotis(at)gmail.com)>wrote:
From: joe motis <joemotis(at)gmail.com (joemotis(at)gmail.com)>
Subject: Zenith750-List: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustration 2 Angle dimension given is 40 mm should be 52 mm?
To: zenith750-list(at)matronics.com (zenith750-list(at)matronics.com)
Date: Sunday, February 7, 2010, 5:11 PM
---------- Forwarded message ----------
Date: Sun, Feb 7, 2010 at 3:09 PM
Subject: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustration 2 Angle dimension given is 40 mm should be 52 mm?
To: joe motis <joemotis(at)gmail.com>
Hi Listers,
I am building the wing spars and I made both upper spar caps with a 40 mm diimension on the angle cut end. It does not fit the way it is supposed to. The actual measurement needs to be 52 mm. The 80 mm up and 272 mm over dimension have both been checked and are correct for the spar angle.
Anyone else have this issue?.
Page 75-W-2 Illustration 2 Upper spar cap
Joe Motis
CH 750 WW Corvair
" target="_blank">http://www.matronics.com/Navigator?Zenith750-List
ttp://forums.matronics.com
- The Matronics Zenith750-List Email Forum -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
