Transponder
rwayne(at)gamewood.net
PostPosted: Wed Jan 11, 2006 6:35 am    Post subject: Transponder Reply with quote
Just for some clarification, the transponder check is required every 24
calendar months regardless of were you fly, if you are going to turn it on.
You are required, however, to have a transponder only in certain airspace.
(In Class C and B, above C and B, under B, in the 30 mile veil and 18,000msl
and above (Class A)). It is the same check whether you fly IFR or VFR. IFR
also requires a pitot-static/ Altimeter check every 24 months.
They grilled me on all this stuff when I took my CFI checkride the other
day.
Wayne8A
