Mounting Lasar unit
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
recapen(at)earthlink.net
PostPosted: Sat Apr 15, 2006 2:03 pm    Post subject: Mounting Lasar unit Reply with quote
Folks,
I'm getting ready to put my Lasar computer on the firewall (where I've seen them before in pictures).  for those of you that have this ignition system, are you putting some backing plates to spread the load out - or just nutplating it in?
Ralph
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
PeterHunt1(at)aol.com
PostPosted: Sun Apr 16, 2006 6:55 am    Post subject: Mounting Lasar Unit Reply with quote
Ralph, I mounted my Lasar computer unit high on the engine side of my firewall on the passenger side of airplane and did not use any backing plate.  I used nutplates to facilitate later removal if necessary.  No problems with that mounting.
As a heads up, I found my CHTs run hot on takeoff and Lycoming claims that is an issue with their Lasar system.  I pull the power a bit just after lift-off and that helps.  Lasar, however gives me great fuel economy - 6.2 gph at 65% power.
Pete in Clearwater
RV-6, Reserve Grand Champion, Sun 'n Fun, 2006
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
