Z8 scrapped . . .
PostPosted: Fri Mar 05, 2010 8:31 am    Post subject: Z8 scrapped . . . Reply with quote
I've been wrestling with the design goals for
tying two alternators to their own dedicated
battery busses and then tying one or both
to a main bus.
Alternators using B&C alternator controllers
are not suited to this idea at all. They're
marginally okay if one of the alternators is
the SD-20 with an SB-1 regulator set to "relax"
the SD-20 when the main alternator is functional
(al la Z-12). But managing the input terminals
to the alternator controllers from an always
hot battery bus adds more poles to a DC
MASTER switch or adds complexity to the system
when handled with multiple switches . . . with
an attendant risk of mis-positioned switches
causing mis-behaviors.
There's also the issue of compliance with the
legacy "switches-off, max-cold" philosophy
for fat wires. The design demands either
b-lead disconnect contactors or fat diodes
on heat sinks.
The design looks better with internally regulated
alternators because they don't have the LV warning
systems and they do regulated voltage sensing
internally at the b-lead. But this demands b-lead
contactors as opposed to b-lead diodes because
the voltage drop across the diode cannot be
compensated for by sensing bus volts downstream
of the diode. So one COULD do some Z24-like
implementations of two alternators driving
dedicated batteries . . . but we still have
paralleling issues and increased pilot workload
to properly position switches.
The system was looking like we needed 5 contactors
total. 2 battery, 2 b-lead, 1 starter.
Finally, with the Z-8 dual-battery/dual-alternator
configuration, you can't have both alternators
driving the main bus at the same time . . . because
of load sharing issues. So this means that while
you can have both alternators running to support
their respective flying loads, only one can be
connected to the main bus at a time.
If one wants two, capable alternators and two
batteries, then Z-14 is still the architecture
of choice offering totally independent systems
with cross-tie capabilities. Z-13/8 is still the
elegant choice for low-cost, light-weight,
simple-operation.
This has been a useful exercise in that it validates
the work already published and illuminated the
messiness of what was initially perceived as another
recipe for success.
My recommendations for optimizing Noah's adaptation
of an SD-20 into his project is replace the SB-1
regulator with a generic "ford" style regulator,
add a b-lead contactor to implement fat-wire
disconnection when parked. Take field power/
voltage sensing directly from the battery bus
through a fusible link then to 5A breaker, crowbar
ovm and then to contactor+regulator bus
connection. Placard the system against
simultaneous operation of both alternators.
PostPosted: Fri Mar 05, 2010 8:46 am    Post subject: Z8 scrapped . . . Reply with quote
ALTERNATIVELY
Consider going to Z-14. Use aux battery consistent
with experimentation to deduce smallest
satisfactory performance. Set the SB-1
up to 14.4 volts.
jonlaury
PostPosted: Sun Mar 07, 2010 7:27 pm    Post subject: Re: Z8 scrapped . . . Reply with quote
nuckolls.bob(at)aeroelect wrote:
... SNIP
Bob, previously I stated my desire to use a standby 30a ER alternator in place of the SD 8 in Z-13/8. I've been lurking as others, like Noah, pushed the thread.
I have a B&C LR-3 for the main alt and intended to use another one for the standby. I have a mechanical "either, or" lockout device for the two alternator field switches. As long as the two systems are mutually exclusive, am I correct to understand that the prohibition re dual LR-3's, mentioned at the beginning of your post, no longer applys? And that the suggested mods in the quote above for Noah's system would not apply to Z-13/8 as I intend to modify it?
John
longg(at)pjm.com
PostPosted: Mon Mar 08, 2010 7:07 am    Post subject: Z8 scrapped . . . Reply with quote
John,
I'm vaguely interested. What is it you are running that requires 30 amps
of power running as a backup? Is that air-conditioning? If you're
essential + engine bus pulls 30 amps, you've got big dependencies. This
is a backup up right, ala emergency power source?
Glenn E. Long
PostPosted: Mon Mar 08, 2010 7:13 am    Post subject: Z8 scrapped . . . Reply with quote
Understand.
Generally. Here's some data points to ponder for
creative integration of two alternators onto a
single bus:
(1) You can have two alternators "always on" but
be aware that their ability to share total loads
is poor to nil . . . it takes special regulators
that talk to each other and direct the choir for
the proper mix of field excitation. Hence it is
recommended that two alternators be used in a main/sb
or main/aux mode where one is used to back up the
other.
(2) You can still operate in an always-on mode IF
you set the regulator setpoint for the aux alternator
about a volt lower than the main alternator. Like
the SB-1 controller functionality illustrated in
Z12. This provides an automatic transfer of load
to the aux alternator if the main shuts down.
CAUTION
This configuration offers a risk of NOT being
aware of a main alternator failure. The SB-1
regulator has circuitry that senses when the
aux alternator becomes loaded and lights a light.
That same light is use to annunciate alternator
overload . . . reduce loads until the light stops
flashing. If you don't have and SB-1, then some
simple circuit that watches alternator field
voltage and lights a light for anything over
1 volt of applied excitation is called for.
(3) You can operate in an either/or mode where
only one alternator is switched on at a time.
In this case, a low volts warning light prompts
the changeover.
CAUTION
I would advise against wiring the two systems
such than turning one alternator on disables the
other. There is no risk to hardware by having both
alternators on at a time . . . but crafting circuits
common to both systems adds a risk of single failure
disabling both alternators. Keep them separate.
Beyond these three rules-of-thumb, I recommend striving
for max-cold of ship's wiring when all switches are
off. Try to limit protection for small always-hot
wires to 5A breakered, 7A fused. Strive for minimum
parts count. Strive for simple switching protocols
that limit if not eliminate any possibility that
mis-positioning of switches can go unnoticed and
negate your best laid plans and fondest wishes.
All of these ideas are NOT regulations. Just because
you do something that is not specifically illustrated
in the Z-figures is not necessarily courting unhappy
days in the cockpit. We build experimental airplanes
and exploration of alternative recipes for success
is encouraged . . . with limitations. Study, understand
and take action by DESIGN to eliminate single points
of system failure . . . which INCLUDES pilot understanding
of how the system will or will not function.
jonlaury
PostPosted: Mon Mar 08, 2010 11:15 am    Post subject: Re: Z8 scrapped . . . Reply with quote
longg(at)pjm.com wrote:
John,
Glenn E. Long
Hi Glenn,
I like to do arc welding while flying Wink.
I was initially considering Z-19 but was always a little uncomfortable with the finite supply of power if alt 1 quit. So it wasn't so much that I needed 30 amps (it's a 40a unit, but pulleyed to reduce wear, so 30 a (at) max cruise rpm) as what was available at a reasonable price and weight. Ignition, fuel pump, EFI , navcom, EFIS put my electrical needs at about 12-15 amps. With just engine needs at about 10-12 amps.
The extra alternator gives me more comfort and less weight for the same cost than an extra battery.
John
flagstone(at)cox.net
PostPosted: Mon Mar 08, 2010 12:05 pm    Post subject: Z8 scrapped . . . Reply with quote
Hi Bob:
Excellent description. I have a follow-up questions to #2:
[quote] (2) You can still operate in an always-on mode IF
CAUTION
Wouldn't the aux come on whenever the system loads exceed the main alternator's capability and the system voltage drops below the set point of the aux regulator, not just when the main alternator fails? So set up in that configuration, wouldn't the two LR-3's work just like the LR-3/SB-1 combination except for the annunciation function? Then, wouldn't you be able to tell which alternators are on and how hard each is working by the load meters? In that situation, does it really matter if they don't share the loads?
Mark
jonlaury
PostPosted: Mon Mar 08, 2010 12:13 pm    Post subject: Re: Z8 scrapped . . . Reply with quote
single bus:
....SNIP....
Give a man a fish and he eats for a day.
Teach a man to fish and he eats for a lifetime.
I am now a fisherman.
Thanks Bob.
John
PostPosted: Mon Mar 08, 2010 1:17 pm    Post subject: Z8 scrapped . . . Reply with quote
Very perceptive. You're correct. The caveat is to make SURE
the alternator with the higher setpoint is adequately cooled.
There have been any number of advisors calling for de-rating
an alternator's load or adjusting pulleys to slow it down . . .
with some notion of increasing service life for forestalling
early failure due to "working too hard".
Every alternator is capable of running for rated service
life (usually thousands of hours) at FULL rated output.
If the OBAM aircraft community is guilty of an important
function of well considered design is that we generally
haven't got a clue as to how well we cool . . . or don't
cool some temperature sensitive components.
There are thousands of 60A or larger alternators flying
very successfully on OBAM aircraft with very low failure
rates due to overheating. But this probably has more to
do with accidental de-rating. Few airplanes need more than
20A of snort for 90 plus percent of their missions.
Many of those builders thinks he can install some power
hungry electro-whizzy because he believes he's got lots
of headroom in the as-installed alternator.
When we certify a new alternator, rules of the game
call for an extended climb at Vy with the alternator loaded
to full rated output. We plot the temperature rise curve
in order to extrapolate the asymptote (temperature rise
ceiling). We then correct for hot day conditions. Anticipated
worst case for temperatures on diode heatsinks and stator
windings cannot exceed manufacturer's ratings.
So before you launch off to deliberately allow one
alternator to operate continuously in a current limited
condition (usually a few percent higher than nameplate
rating), be prepared to determine that the alternator
is not running with one foot in a bucket and the other
in a fire.
Back in the heyday of light twins with generators,
turning on all electro-whizzies demanded that BOTH
power sources carried their "share" of the load.
This is really easy to do with carbon pile regulators.
A simple equalizer winding added to the regulator's
magnetics would allow the two regulators to compare
notes and shift loads between generators for balancing.
http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators.jpg
Sharing was important then because service life (brush
wear) was affected by system loads. Alternators do
not suffer such problems . . . but they're more difficult
to parallel too.
Designing a system that expects one of two alternators
to operate in a current limited mode is not an automatic
recipe for failure . . . but you need to do your
homework.
Bob . . . [quote][b]
PostPosted: Mon Mar 08, 2010 1:29 pm    Post subject: Z8 scrapped . . . Reply with quote
Service life is not enhanced by slowing it down.
Performance in the original automotive application
counted on thousands of hours under condtions far
worse than on your airplane. If you'd really like
to get 40A from it, change the pulley ratio. It
will run cooler by turning faster for the same
load.
( -Thomas Paine 1776- )
Thanks Bob.
Thank YOU for helping spread the value of
what this List has to share.
jonlaury
PostPosted: Mon Mar 08, 2010 5:45 pm    Post subject: Re: Z8 scrapped . . . Reply with quote
load.
AHA! Point taken.
J
DO NOT ARCHIVE
