cjhukill(at)cox.net Guest
Posted: Tue Mar 16, 2010 9:55 am Post subject: Jump start |
I am doing it the same way as my RV8. I have a cigar lighter plug near the battery for trickle charge and avionics work, and a door in the baggage bulkhead thru which I reach in to attach standard automotive jumper cables to the hot lug of the master contactor and a grounding lug. Now in the rare event you need an emergency jump to leave town, any passing motorist has the cables you need. No dead weight in the airplane. I actually had several occasions to need that setup in the RV8, all due to a bad starter that depleted my battery trying to get started. After finding that and replacing it, never had a need for jumping since.
Chris Hukill
Wiring the machine
