Kelly McMullen
Posted: Tue Mar 23, 2010 5:04 am Post subject: New Vertical Power Product |
Just when I was beginning to weigh the options of VP200 or
conventional breakers, or VP100, VP goes and drops the VP100 and comes
out with new product, the VPX, which does much of what the VP200 does,
without the display, using the EFIS of choice. I don't know if many
have discovered this yet. It appears to play with AFS and GRT, but not
Dynon Skyview at this point. Price point is very attractive, at $1800
for unit, 400 for harness. So back to studying documents and more
decisions. Of course it also muddles the EFIS decision tree.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Tue Mar 23, 2010 6:56 am Post subject: New Vertical Power Product |
I've talked to Dynon about it and they said that if enough people tell them they want it, they will support it. Those who are planning SkyView and considering VP-X, flood Dynon with calls asking them to support it. For a budget panel, I think that's a great combination.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 23, 2010, at 9:04 AM, Kelly McMullen wrote:
Phil.Perry(at)netapp.com Guest
Posted: Tue Mar 23, 2010 8:33 am Post subject: New Vertical Power Product |
I'd like to see it attach to the lower-end Dynon's.
I'd like to have the D-6 for a backup instrumentation. But it would be
really cool to use that display for your electrical, but then have it as
a backup EFIS in case you need it.
I have no clue if there's even a port on the D-6 to do that, but the
idea is pretty cool.
Phil
jcumins(at)jcis.net Guest
Posted: Tue Mar 23, 2010 8:39 am Post subject: New Vertical Power Product |
WOW this is great news. Will for sure check it out at OSHKOSH.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
Posted: Tue Mar 23, 2010 8:45 am Post subject: New Vertical Power Product |
Additionally, let Dynon know if the VP-200 is part of your stack as that
helps a consumer driven company prioritize what is top of the list or not.
They are currently working on the VP-200 integration BTW.
Marc's new product looks great. I expect that SkyView will interface with it
as soon as we can. I'd like to know how many people are planning to install
the VP-X. If you email me, please include how soon you plan to install it.
I'd also be interested in know which model RV, and whether you are building
new or retrofitting.
Robert
Dynon Marketing
Sent: Tuesday, March 23, 2010 7:53 AM
Subject: Re: New Vertical Power Product
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
glastar(at)gmx.net Guest
Posted: Tue Mar 23, 2010 9:22 am Post subject: New Vertical Power Product |
Perry,
I'm afraid that will not happen.
The D6 neither I guess the other D series will have the necessary space
for further program code to interface with the VP-X the Skyview series
is the only hardware tehy have which will be capable.
br
Werner
Phil
Posted: Tue Mar 23, 2010 10:44 am Post subject: New Vertical Power Product |
I am sure the D-6 won't offer it, because the D-6 is made specifically to be a stand-alone EFIS, that doesn't even integrate with other Dynon units. The D100-D180 products will probably not offer that option either because of the complexity of the interface with VP as well as the desire for Dynon to encourage people into the SkyView system. I don't see any reason why a single small-screen SkyView couldn't be a backup and also the VP interface, although I assume the sharing of Engine Data would be a big part of the SkyView-VP interface, so you would need to have the SkyView be your engine monitor, probably.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Phil
Kelly McMullen
Posted: Tue Mar 23, 2010 1:28 pm Post subject: New Vertical Power Product |
Seems to me the choice is between VP-200 or VP-X with Skyview. The
rest of Dyon products are either going obsolete or for backup.
Certainly VP-X is a lot cheaper, but VP-200 does a fair amount more.
Biggest issue is getting engine monitoring to share info.
On Tue, Mar 23, 2010 at 11:42 AM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> Phil
KCHD |
