Throttle, Prop, and Mixture cable slack
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
recapen(at)earthlink.net
PostPosted: Tue Apr 18, 2006 12:08 pm    Post subject: Throttle, Prop, and Mixture cable slack Reply with quote
Fellow listers,
I'm working on my firewall foreward and since I had already made some decisions before the firewall foreward kit was available, I can't use the stock locations for my throttle and mixture cables. The prop cable went in to the stock location nicely with the one hole eyeball fitting.
There seems to be just a little slack in that cable - just enough to allow flexibility to keep it out of the way.
How much should I have? Upon measuring the cables that I got for the throttle and mixture after putting them in where I could, I have 6" too much throttle cable and 7" too much mixture cable. These are straight shot from the panel/console to the eyeball passthrough the firewall. on the firewall side, I have sufficient 'Lycoming wet dog shake room'. I'm thinking on the aft side of the firewall, I don't need much wiggle room other than to avoid stuff that could get in the way and wear the cable.
Your thoughts please,
Ralph
RV6AQB N822AR (at) N06 - fun firewall foreward!
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
