Replacing the brakes & wheels on my Allegro
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
jlhazen(at)copper.net
PostPosted: Mon Apr 05, 2010 9:39 am    Post subject: Replacing the brakes & wheels on my Allegro Reply with quote
Are you going to change the nose tire? I have thought about bigger tires for back country dirt strips but nosewheel clearance seems to be an issue.
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
timpry
PostPosted: Tue Apr 06, 2010 6:46 am    Post subject: Re: Replacing the brakes & wheels on my Allegro Reply with quote
I was not planning on replacing the nose wheel.
hgmckay
PostPosted: Mon Apr 12, 2010 12:42 pm    Post subject: Replacing the brakes & wheels on my Allegro Reply with quote
Please do post pictures of this project. I have an Allegro 2000 and am
having the hydraulic brakes tend to periodically stick (i.e. the shoe not
relaxing off of the disc). I think this may be be caused by the small
hydraulic piston in the caliper sticking. It does not do do this all the
time, and I only see it after I have landed and am trying to move the plane
by hand. If the plane sits over night the problem is gone. Anyway, if I
can't find out how to correct this problem on the brakes I now have I may
have to change in the future.
Hugh McKay
Allegro 2000
Rotax 912 UL
N661WW
Sent: Monday, April 12, 2010 9:47 AM
To: <allegro-list(at)matronics.com>
Subject: Re: Replacing the brakes & wheels on my Allegro
Well I am still not quite done with this project.. The primary problem
was the T fitting I bought from aircraft spruce was supposed to have 1
1/8" npt and 2 1/8" compression fittings. It had 3 1/8" compression
fittings instead.. I am ordering a second T fitting in the hope that it
will be correct.
The new wheels, tires, brakes, brake lines & master cylinder are
installed.. everything is looking fine.
Major parts list:
Matco MHMHE6B1.25 EV (matco wheel / brake assembly)
Matco WHLAXLE3EV (matco axle)
matco Mc-5 master cylinder
MCCREARY AIRTRAC 600-6 tires
high pressure tubing, right angle and t fittings, aircraft quality bolts,
washers, lock nuts.
I would probably recommend using 1/4" brake line.. since it is a LOT
easier to find fittings in this size.. in the event you are missing
something.. say a T fitting...
Total cost of materials was about $900
total time invested so far.. about 20 man hours.
I will probably post pictures of the finished product once everything is
complete.
http://forums.matronics.com/viewtopic.php?p=293954#293954
Thom Riddle
PostPosted: Tue Apr 13, 2010 3:02 am    Post subject: Re: Replacing the brakes & wheels on my Allegro Reply with quote
I have Matco brakes on my Kolb Slingshot and they are good brakes but if I were going to change Allegro brakes to a different type I would probably choose the following:
http://www.flyfbi.com/html/hydraulic_brakes.html
I was giving a BFR to a Challenger owner last year in his airplane which had these brakes installed. The best braking action I've seen on an LSA and inexpensive.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
hgmckay
PostPosted: Tue Apr 20, 2010 5:00 pm    Post subject: Replacing the brakes & wheels on my Allegro Reply with quote
Can you post a picture of the Matco brakes as they appear on your Allegro?
Hugh McKay
Allegro 2000
Rotax 912 UL
N661WW
Sent: Tuesday, April 20, 2010 10:25 AM
Well I finally got a chance to condition the brakes.. and give them a
proper test. On their best day the Evektor brakes would barely hold the
plane at 3500rpm. I stopped testing the Matco brakes at 4900 rpm. So
I would say they are an improvement... Also they appear to be easier and
cheaper to maintain.
Overall I am pretty happy with the decision and the results.
http://forums.matronics.com/viewtopic.php?p=294956#294956
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
