prop pitch question
tigerrick(at)mindspring.c
PostPosted: Mon Apr 17, 2006 1:25 pm    Post subject: prop pitch question Reply with quote
Hi, Thomas!
I also have a '76 that is now equipped with a 63" pitch Sensenich, and
it does just fine high and hot when flown right. Dave Fletcher
maintains that the 62" is the ideal for most applications, and I don't
doubt him at all. I don't have the PF exhaust either, but I'm a nut
about engine maintenance, leaning, and a third flap on take off, so I've
been happy with the 63" while getting all out of the O-360 that it has
to offer.
The 64" can be repitched down to 63", but it sounds like you'd be better
off with the 62" - fly it awhile, and if you want a couple more knots at
cruise and a bit less climb, you could pitch it up an inch.
Just my opinion, obviously.
Rick Lindstrom
N74613
N4526B
N9738U
airman(at)appledumplings.com wrote:
Originally sent this to the grumman-gang list with an "unacceptable
subject line" and got bounced by the gg-list nazi. figured I would
try here.
>I bought a 76 tiger and am getting a new sensenich prop. The
>problem is that the only pitch that they have is the 64" pitch prop
>available ... i was looking at 62" or 63" pitch but they say 6-12
>weeks. Repitching is extra So either I go with the 64 or i go
>pick it up and do the prop later.
>It doesnt have any performance mods like the power flow or anything
>so I am unsure what the max pitch I should consider.
>I have no experience in tigers so recommendations would be
>helpful. I plan to use it for my ifr training and flights back
>and forth to in-laws about 4-500 miles. I also will be going to a
>sea level airport of 2300' long on and off.
>Thanks in advance,
>Thomas
>N74225
flyv35b(at)ashcreekwirele
PostPosted: Tue Apr 18, 2006 6:09 am    Post subject: prop pitch question Reply with quote
With your longer x-country flights I'd go with the 64" and see how it works.
You can always repitch it later on or add the PF exhaust and then you
wouldn't want to. I doubt if a 2300 ft. strip will be a problem with a 64"
pitch prop unless there are tall obstructions right off the end. I have
flown a Tiger in an out of a 1500 ft. strip in the past with a 63" pitch.
Cliff A&P/IA
GrummanDude
PostPosted: Tue Apr 18, 2006 10:52 pm    Post subject: prop pitch question Reply with quote
Most Tigers won't do very well with a 64" pitch. The original blank, if I'm
not mistaken, is made with a 62" pitch, so, it's already been twisted 2
inches. If you twist it back 2 inches, that's 4 inches it's been twisted already.
It can only be twisted a total of 8 inches ........ So, with that said,
Depending on how strong your engine is, I'd see if I could get a custom twist
with the twist at 64-62-60. The average is 62 which is a legal pitch for
the Tiger. But, you get back about 75 to 100 rpm and you don't give up much in
cruise. maybe 2 knots.
Gary
AuCountry Aviation
Home of Team Grumman
bruce.smith(at)york.com
PostPosted: Wed Apr 19, 2006 4:07 am    Post subject: prop pitch question Reply with quote
Gary,
What is the position of the measurements you have listed below for
pitch. I'm guessing that the 62 is midpoint on the blade. Correct?
Bruce
twist
GrummanDude
PostPosted: Wed Apr 19, 2006 10:59 am    Post subject: prop pitch question Reply with quote
In a message dated 4/19/06 5:08:00 AM, bruce.smith(at)york.com writes:
64 (first third, near the hub) - 62 (middle) - 60 (tip).
And, I should have said you'll get back about 150 rpm for climb.
A certain someone I know had one of the new Cheetah Sensenich props pitched
63-62-61, gained 200 fpm rate of climb AND gained 2 knots. But, he was able
to run WAY over redline at 7500 feet. Now, he can turn redline at 9000
feet.
Gary
AuCountry Aviation
PostPosted: Wed Apr 19, 2006 11:37 am    Post subject: prop pitch question Reply with quote
I would imagine that this is in a Cheetah with the HC mod that's been
further massaged by the folks at Lycon. I wonder what that kind of an
engine might produce on a dyno...
Bruce
TeamGrumman(at)aol.com said the following on 4/19/2006 2:57 PM:
feet.
GrummanDude
PostPosted: Wed Apr 19, 2006 8:38 pm    Post subject: prop pitch question Reply with quote
In a message dated 4/19/06 12:37:54 PM, bruce.smith(at)york.com writes:
Bruce
actually, no. This engine has 1500+ SMOH. 77 Cheetah. Nothing trick on
this plane except a red rudder cap. Trues at 132 knots.
Gary
AuCountry Aviation
aa1bflyboy(at)msn.com
PostPosted: Wed Apr 19, 2006 8:53 pm    Post subject: prop pitch question Reply with quote
Has anyone evr done this with a prop for an AA1x model?
Steve Roberts - AA-1B N9664L (at) ILG
able
feet.
FLYaDIVE(at)AOL.COM
PostPosted: Thu Apr 20, 2006 3:15 am    Post subject: prop pitch question Reply with quote
Steve:
ALL PROPS have different pitches at different stations along their length.
This is not a speed mod or a magic dust trick.
The only trick in picking a pitch is to go has high as you can without
failing the ground static check.
Barry
"Chop'd Liver"
In a message dated 4/20/06 12:54:23 AM Eastern Daylight Time,
aa1bflyboy(at)msn.com writes:
pitched 63-62-61, gained 200 fpm rate of climb AND gained 2 knots. But, he was
able to run WAY over redline at 7500 feet. Now, he can turn redline at
9000
feet.
PostPosted: Thu Apr 20, 2006 3:38 am    Post subject: prop pitch question Reply with quote
Barry,
I thought this was the case, but had never heard it expressed in this
manner. It was always that this Tiger has X pitch or this Cessna has Y
pitch.
Thanks.
Bruce
FLYaDIVE(at)aol.com said the following on 4/20/2006 7:15 AM:
Steve:
Barry
"Chop'd Liver"
9000
> feet.
PostPosted: Thu Apr 20, 2006 5:20 am    Post subject: prop pitch question Reply with quote
Yes there are different blade ANGLES specified for a PARTICULAR pitch at
ever station. What Gary is saying that these specific angles are deviated
from to essentially achieve what would be the angle for a 64" pitch at the
inner third and changing to what would be a 60" pitch angle at the tip.
This is not common and some prop shops simply won't do it, saying they can
legally deviate from the specified angles for a particular pitch.
Cliff
PostPosted: Thu Apr 20, 2006 5:56 am    Post subject: prop pitch question Reply with quote
Should have said "they can't legally deviated"
PostPosted: Thu Apr 20, 2006 8:20 am    Post subject: prop pitch question Reply with quote
Yeah that's what I though too..
Do a lot, get a little;
Do a little, get a lot;
Do nothing, get it all.
----Original Message Follows----
Reply-To: teamgrumman-list(at)matronics.com
Subject: Re: prop pitch question
Date: Thu, 20 Apr 2006 07:37:58 -0400
Barry,
pitch.
Thanks.
Bruce
> Steve:
length.
> Barry
> "Chop'd Liver"
<aa1bflyboy(at)msn.com>
But, he was
at
> 9000
>> feet.
GrummanDude
PostPosted: Thu Apr 20, 2006 10:16 am    Post subject: prop pitch question Reply with quote
In a message dated 4/20/06 4:16:30 AM, FLYaDIVE(at)AOL.COM writes:
ALL PROPS have different pitches at different stations along their length.=A0
true, and not true.
for a 64" pitch, there are specific angles, in degrees, for each station.
For a 62" pitch likewise. Making an airfoil that conforms to the different
primary pitches, really changes the way the prop performs.
It's used in racing at Reno all the time.
Gary
AuCountry Aviation
FLYaDIVE(at)aol.com
PostPosted: Thu Apr 20, 2006 6:12 pm    Post subject: prop pitch question Reply with quote
In a message dated 4/20/06 2:17:10 PM Eastern Daylight Time,
TeamGrumman(at)aol.com writes:
length.> A0
true, and not true.
different
So ... Isn't that what I said?
Chop'd Liver rides again!
GrummanDude
PostPosted: Thu Apr 20, 2006 9:31 pm    Post subject: prop pitch question Reply with quote
In a message dated 4/20/06 7:12:51 PM, FLYaDIVE(at)aol.com writes:
Oh, hell, I guess. From your understanding of what I said, that is what you
said. Yes, "ALL PROPS have different pitches at different stations along
their length." I don't think you understand the concept of variable twist
along the blade as used by racers with fixed pitch props. That is what I was
talking about. And that is what Cliff was referring to. It really isn't worth
trying to explain.
Let's just say a stock Cheetah Sensenich prop Model 74DM7S10-1.5-61P (61 inch
pitch) on a Cheetah that trues at 128 knots (at 5500 feet and 2650 rpm) and
has trouble pulling over 2700 rpm at 10,000 feet, when given a custom twist
with an average 62 inch pitch across the blade, GAINED 200 fpm rate of climb at
an airport at 2000 AGL, Trues at 132 knots (at 5500 feet and 2650 rpm) and can
still turn 2700 rpm at 10,000 feet, well.....
Anytime something can be done to increase climb rate, increase true airspeed,
and not give up horsepower (RPM) at altitude by over loading the prop, I'd
say that's a magic dust trick.
Gary
AuCountry Aviation
