sstearns2(at)yahoo.com Guest
Posted: Sat Jun 19, 2010 12:39 pm Post subject: first flight |
Hello all,
I flew my TR-1 taildragger for the first time a few days ago. It went well and ended safely.
The engine CHTs and oil ran pretty hot, so I've opened up the cooling exit area and plan to make a set of pressure recovery intake ducts. The engine also only has about 4 hours on it, so it might still be hot from break in. It's a "180 HP" IO-360 that makes 220 HP, but I never ran it over 25" and was flying at 20-22" most of the time due to the high temps and trying to keep it from going building up too much speed. The data logging capability of the dynon units are a great help for fligh test.
It also wanted to roll left even with full trim in, but the stick forces were low and I may not have had the ball fully centered. I'm installing a fixed trim tab.
I had the flap and strobe circuit breakers pop due to being undersized. Easy fix.
It seeds to handle well. The pitch and roll forces seem about equal. My elevator is 2 inches longer in chord than stock, which helped increase the pitch force.
Scott
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lgdavid(at)roadrunner.com Guest
Posted: Sat Jun 19, 2010 1:29 pm Post subject: first flight |
Scott, Congrats! What take off and landing speed did you use? Any instability like has been advertized when slower in ground effect? Congrats again. Feels great doesn't it. Larry
gbrighton(at)skymesh.com. Guest
Posted: Sat Jun 19, 2010 4:52 pm Post subject: first flight |
Great news Scott and congratulations from 'down under too' .... Busting to hear more as u progress along ... I have the standard Elevator and its way light ... Well Done .
Graham
Posted: Sat Jun 19, 2010 6:39 pm Post subject: first flight |
Hi Larry,
I'm not sure exaclty what speed I lifted off at, but it was pretty fast. Between 75 and 80 KIAS for lift off looking at the data. As best I can tell from the data i touched down at about 60 knots. I was overcontrolling it a bit, but it felt solid and responsive all the way to impact, I mean touchdown. I need to tuft the wing root fairings and the bottom of the elevator when I have a chase plane and see if there is separation at high AOA.
Scott
--- On Sat, 6/19/10, Larry David <lgdavid(at)roadrunner.com> wrote:
Subject: Re: first flight
To: kis-list(at)matronics.com
Date: Saturday, June 19, 2010, 2:25 PM
ftyoder(at)yoderbuilt.com Guest
Posted: Sat Jun 19, 2010 7:29 pm Post subject: first flight |
Congratulations!
Flyinisfun(at)aol.com Guest
Posted: Sat Jun 19, 2010 8:34 pm Post subject: first flight |
Hi Larry,
I would like to know what your empty weight is and how your CG came out. Sounds like you have a good balance. How much gas did you have on your first flight. Full --- Half full ---- or maybe a total of 10 gallons?
Thanks, Jesse
