Flaring tool
mountain4don(at)yahoo.com
PostPosted: Wed Jan 11, 2006 6:32 am    Post subject: Flaring tool Reply with quote
I am in need of a 37 degree flaring tool to flare the 3/16" aluminum lines from my Dynon AOA pitot. I have used a flaring tool a lot of years ago, but don't know what to look for. Does anybody have a recommendation on where to buy one or a make and model that works well? It seems that a lot of them are 45 degree flares. Are they used in auto brake lines or water pipes or something? Also some of them are listed as a double flare. Do I need a single flare? Do local hardware stores or auto supply stores sell them?
bbartlett5(at)satx.rr.com
PostPosted: Wed Jan 11, 2006 7:07 am    Post subject: Flaring tool Reply with quote
I got my 37 degree flaring on eBay. Give it a try...
w1mdi(at)cox.net
PostPosted: Wed Jan 11, 2006 7:30 am    Post subject: Flaring tool Reply with quote
Don
I warmed up the plastic pitot line a little bit and was able to slide it
over the Dynon leads. With hose clamps, it is very air tight.
Winston Ellis
CH701/Suzuki
Ketchum, Idaho
Don Mountain wrote:
I am in need of a 37 degree flaring tool to flare the 3/16" aluminum lines from my Dynon AOA pitot....
japhillipsga(at)aol.com
PostPosted: Wed Jan 11, 2006 7:59 am    Post subject: Flaring tool Reply with quote
Don, I purchased mine from Spruce.
cgalley(at)qcbc.org
PostPosted: Wed Jan 11, 2006 8:06 am    Post subject: Flaring tool Reply with quote
Check with your local EAA Chapter. Many like mine have a tool library. You
could also borrow one for the little you need it. Once done, unless you
damage a tube, you will never need it again.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
CLEONARD52(at)comcast.net
PostPosted: Wed Jan 11, 2006 1:44 pm    Post subject: Flaring tool Reply with quote
LOOK IN THE SUMMIT RACING WEB SITE.
