Fuse Mid Side Skin Bending - F1070R
owl40188(at)yahoo.com
PostPosted: Tue Jan 03, 2006 9:43 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
I tried to bend the F1070R fuse skin yesterday.  It didn't go too well.  I ended up with a tear in the skin at the forward end of the bend line.  I think my problem was that instead of making the bending block out of hardwood I used 2 by 6 construction lumber which is much weeker.  As a result the edge of the bending block broke.  Ordered new skin ($75) and a will be getting a piece of oak to make the new bending block.  Has anyone had a similar experience?  Any suggestions on this?
Niko
40188 Fuselage
deemsdavis(at)cox.net
PostPosted: Tue Jan 03, 2006 10:03 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
I talked to Bob Condrey # OSH about this, If I recall correctly he had
porblems initially, but came up with a great solution for bending these.
I believe he posted it on the list, but i can't recall.
Bob, you out there?
Deems Davis # 406
Wings
http://deemsrv10.com/
on this?
bob.condrey(at)baesystems
PostPosted: Tue Jan 03, 2006 10:22 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
Rolling the fuselage skins can be pretty tough (especially the front ones).  Making the bending/rolling block out of a hardwood is imperative!  Also, there are a couple other tips that Tim posted on his website at http://www.myrv10.com/tips/fusetips.html.  Scroll down to the bottom for the skin rolling stuff.
Bob #40105
Finish kit: Installing windows
n223rv(at)wolflakeairport
PostPosted: Mon Jan 09, 2006 6:31 pm    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
Talk to Van's.  When I was talking to them about this, they mentioned it may be rolled from the factory now.  Not sure if they were talking about the front or the rear, but they were working on having them formed from the factory.
PostPosted: Wed Jan 11, 2006 6:12 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
rene(at)felker.com
PostPosted: Wed Jan 11, 2006 6:27 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
PostPosted: Wed Jan 11, 2006 9:21 am    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
Thanks for the info.
jim(at)CombsFive.Com
PostPosted: Wed Jan 11, 2006 2:49 pm    Post subject: Fuse Mid Side Skin Bending - F1070R Reply with quote
Niko,
I don't have access right now to the plans, but they do tell you to bend both panels. You will want to do the bend BEFORE you cut the baggage door from the side panel. It helps keep the panel a little more rigid.
Jim C
#40192 - Fuselage
N312F Reserved
Date: 2006/01/11 Wed AM 09:11:45 EST
Subject: Re: Fuse Mid Side Skin Bending - F1070R
Does the F1070L skin (the one with the baggage door cutout) get bent the same time the F1070R does? I don't see any mention of it at all.
