ejessee
Posted: Mon Aug 02, 2010 5:29 am Post subject: a close call -- rubber spacers dry-rotted |
Hello all, I was flying this weekend in the beautiful Appalachian mountains. I landed at an old friends strip. I had a good landing. As a matter of fact, I have had no "rough landings" in a while. When I landed, the rubber spacers on my main gear split and came out.
Maybe this post will save someones life. Check those spacers. They are very important.
The Psalmist wrote:
... Where can I go from your Spirit? Where can I flee from your presence? If I go up to the heavens, you are there;... If I rise on the wings of the dawn,... even there your hand will guide me, your right hand will hold me fast.
_________________ Ernest Jessee
N4931M
NYTerminat(at)aol.com Guest
Posted: Mon Aug 02, 2010 6:43 am Post subject: a close call -- rubber spacers dry-rotted |
Ernest,
Thanks for sharing your story and giving credit to the Lord. I have always had problems with those rubber spacers breaking down and wearing out and allowing the gear to loosen up to the point it would rock back and forth. I solved the issue with using the sidewall of a truck tire for spacers and have not had any issues since. I am glad that you and your sister are safe.
The links for the pictures are not valid and I was unable to open them up.
Bob Spudis
N701ZX/ CH701/ 912S/ 186hrs
| Quote: | --> Zenith701801-List message posted by: "ejessee" <eejessee(at)us.ibm.com>
Hello all, I was flying this weekend in the beautiful Appalachian mountains. I landed at an old friends strip. I had a good landing. As a matter of fact, I have had no "rough landings" in a while. He wasn't home. Upon takeoff with 2 adults and just as I rotated to lift off, I heard a horrific noise. My first though was that I had dragged the tail, but I didn't think I had rotated that severely. Perhaps there was some obstruction that I hit. I had just landed on that strip and it was asphault. Maybe a dog came out on me. I don't know what happened, but I soon discovered that my gear was not hanging straight.
I flew back to KJFZ and with my sister holding a fire-extinquisher and both of us praying, I had a gear-up landing in my 701.
I am a man of faith. I was scared out of my mind. God landed it this time and boy is he a good pilot. The pictures attached are not staged. This where she stopped.
Afterword, I went to lowes and bought an angel grinder, a drill, a piece of angle, and some rubber hose. I put her back on her gear with the help of 2 beefy newphews. Friends, there isn't a scratch on her except the bolts were severely bent on the right strut backet, tie-down loop was bent, and the bolt heads were ground off the rudder horn attachments. The rudder horn is bent a bit and thus I will replace it I left here in Virginia until I get a new right strut bracket, some new AN bolts, and a new rudder horn. I thought it best to drive back from Virginia anyway and let my nerves settle before I took back to the air.
I have included pictures of the plane where she rested and of the rubber spacers and aluminum brackets holding the sandwich together. The rubber is old -- I should have replaced it earlier. Could this rubber being old have caused this?
Maybe this post will save someones live. Check those spacers. They are very important.
Ernest Jessee
N4931M
http://forums.matronics.com/viewtopic.php?p=307178#307178
http://forums.matronics.com//files/img00004_20100730_1458_406.jp======================== = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Mon Aug 02, 2010 7:11 am Post subject: Re: a close call -- rubber spacers dry-rotted |
I replace the gear mount rubbers every annual with truck side walls like Bob, because I fly out of dirt strips most of the time. I also found that the cheese "L" bracket like yours didn't last very long either. So I replaced it with a piece of 1/2 thick 6060-T6 and that cured the bracket problem. With this maintenance program and the thick bracket I have had no problems for the last three years. I feel very secure now flying out of rough dirts strips.
Rick
_________________ 701Driver
N35 26.700, W118 16.743 |
JohnDRead(at)aol.com Guest
Posted: Mon Aug 02, 2010 8:03 am Post subject: a close call -- rubber spacers dry-rotted |
Zenith has a urethane part for the UC cushions which does not rot.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 8/2/2010 8:43:23 A.M. Mountain Daylight Time, NYTerminat(at)aol.com writes:
| Quote: | Ernest,
Bob Spudis
Ernest Jessee
N4931M
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Mon Aug 02, 2010 10:54 am Post subject: a close call -- rubber spacers dry-rotted |
This is what Caleb at Zenith wrote a few weeks back:
"We supply polyurethane blocks for the rubber spacers now, the part number is 7L2-2A/1. We use those blocks on both top and bottom. We have gotten a lot better life out of the polyurethane than we ever have using rubber. They should be a drop in replacement for the rubber that you have."
They are $6.50 each and you need four.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Monday, August 02, 2010 9:03 AM
Subject: Re: a close call -- rubber spacers dry-rotted
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
| Quote: | Ernest,
Bob Spudis
Ernest Jessee
N4931M
http://forums.matronics.com//files/img00004_20100730_1458_406.jp======================== = Use utilities Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
Posted: Mon Aug 02, 2010 10:56 am Post subject: a close call -- rubber spacers dry-rotted |
If the link to the attachments doesn't work (like it didn't for me) just follow the link below "Read this topic online here:" and scroll down:
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com
Sent: Monday, August 02, 2010 7:42 AM
Ernest,
Bob Spudis
Ernest Jessee
N4931M
Posted: Mon Aug 02, 2010 6:49 pm Post subject: a close call -- rubber spacers dry-rotted |
Craig, I get the feeling that there was another picture that he tried to post other than the parts.
Bob Spudis
In a message dated 8/2/2010 2:56:17 P.M. Eastern Daylight Time, craig(at)craigandjean.com writes:
Posted: Mon Aug 02, 2010 7:51 pm Post subject: a close call -- rubber spacers dry-rotted |
I think you are right but at least this gives us one.
-- Craig
Sent: Monday, August 02, 2010 7:18 PM
Bob Spudis
