engine monitor problem - CHT thermocouples
tonyplane(at)bellsouth.ne
PostPosted: Wed Apr 26, 2006 5:01 am    Post subject: engine monitor problem - CHT thermocouples Reply with quote
Bill,
If your CHT probes are attached to your monitoring instrument, then all you
ahouls have to do is put the "sensening" end of the probe into a know temp
liquid and check your instrument reading. I used to check calibration by
placing the "twisted" end of the thermocouple wire into ice water (32 deg
F/0 deg C) and then into boiling water.
Another thing to do to check the CHT thermocouple position for instrument
reading is to use a hair dryer or other hot air device to put heat onto the
cylinder and check the reading on the instrument. I found that I had two
cylinder location readings reversed when I installed my probes.
Tony Graziano
ZodiacXL/Jab3300A, N493TG, 91 hrs
Time: 09:34:00 AM PST US
Subject: Re: Re: engine monitor problem
Jim, I think I will try to test my probes as you suggested. Again, how would
you do that ? I have a digital thermometer so would I have to get some water
hot and stick the thermometer probe and the CHT probe in there together and
see
the difference in readings ? You mention grounding. Would I have to run a
ground wire from the CHT probe to the engine ? I remember when I purchased
the
CHT kit the instructions mentioned that they could be off by as much as 75
degrees. Best to you, Bill of Georgia, N505WP, 601X-3300 w/dc and 60 plus
hours
JAPhillipsGA(at)aol.com
PostPosted: Wed Apr 26, 2006 6:56 am    Post subject: engine monitor problem - CHT thermocouples Reply with quote
Tony, thanks for the input. I to had two cylinders probes reversed. My real
concern is how much attention I need to pay to the gages. I noticed the other
day that my oil temp went up as the CHTs for 4 & 6 stayed up and moved down as
they went down. I wonder how accurate my oil temp gage is ? Is there a way to
mechanically test this ? When I first started flying her I used a mechanical
gage to test the oil pressure gage and found it reading 10-15 pounds high. Have
you tested yours ? I will be glad to send you the oil gage I used and
fittings if you want. Thanks again, Bill of Georgia
PostPosted: Thu Apr 27, 2006 4:52 am    Post subject: engine monitor problem - CHT thermocouples Reply with quote
Thanks Bill,
I suppose that you could also put the oil temp probe into boiling water
(with it grounded to the engine) and check your temp gauge for a 212F/100C
reading. I find mine reads the same temp as the CHTs (within a couple of
degrees spread among all readings) when the engine is cold, so I am assuming
that the hot readings are OK. My oil press probably reads a few pounds high
as I show 4psi before start, but that does not concern me. I tried another
VDO oil press switch and get about the same readings between the two. I
also attached a red LED to the WK switch (the idiot light switch) on the
VDO, through a relay, which lights up before engine start (zero oil press)
and at very low oil press. It is reassuring to see the LED go out at engine
start up.
I have to watch CHT and oil press when the ambient temp is warm to hot. If
I keep full throttle in climb.below 90 kts I will start approaching red
lines in CHT and oil temp. If oil temp goes near red line, then my oil
press starts to drop. I am using EXon Elite 20W50 oil. My instrumentation
is the Grand Rapids EIS - (It is a really neat instrument - if you go to
max or min for any set parameter, a large red light blinks at you.)
Tony Graziano
Zodiac 601XL, 493TG
Time: 07:56:51 AM PST US
Subject: Re: Re: engine monitor problem - CHT
thermocouples
other
as
to
Have
PostPosted: Thu Apr 27, 2006 6:57 pm    Post subject: engine monitor problem - CHT thermocouples Reply with quote
Tony, I conducted my CHT tests this afternoon and the results were dead spot
on. Course I did not get the oil bath temperature up above 175 as hot oil can
be a problem, but the probes were very accurate up to that point. I' going to
fly into a little fly-in at Larenceville just east of Atlanta Sat morning.
Nice field and folks at the EAA chapter put on a fine breakfast. Several other
601's are bound to be around. Maybe you could make it. Best regards, Bill
