KIS2 Seat issue...absorb shock on impact
jconners(at)dot.state.nv.
PostPosted: Wed Oct 27, 2010 1:23 pm    Post subject: KIS2 Seat issue...absorb shock on impact Reply with quote
There is literature available that provides options for a seat 'cushion' to absorb energy in the event of a crash...'a little goes a long way'...to minimize spinal injuries. I do not have a link for this info...but locatable with some effort. Yes, it does nil for the forward force, but significant for the 'downward' force during a 'controlled' crash.
I remove the cushions and add a thin gel pad...I forget the product name but many options on line.
Using a parachute requires selecting the correct chute to optimizing the seating/headroom restraints of the KIS2.
Jer
PostPosted: Wed Oct 27, 2010 1:35 pm    Post subject: KIS2 Seat issue...absorb shock on impact Reply with quote
http://www.backbenimble.com/gseat-mobility-gel-cushion.htm ... I use something similar to this when I remove the cushions to get the needed 'clearance/headroom'.
Jer
