CDNCH701
Joined: 26 Feb 2009 Posts: 11 Location: Winnipeg, MB Canada
Posted: Sat Oct 30, 2010 8:39 am Post subject: Zenith750-List Digest: 1 Msgs - 10/26/10 (750 front strut p |
Hey ken...
What size is the streamlined aluminum tubing... looking at using for my 701
Ron
-) 750 struts consist of a length of streamlined aluminum tubing, and
-) welded steel fittings that slide into each end.
-) On Sat, Oct 30, 2010 at 5:18 AM, John Flavin
-) wrote:
-)-) I and at least several others encountered this same problem
-)-) with the front strut while building 701's. In our case, the
-)-) relative angle between the lower fitting on the landing gear
-)-) and the upper attach point on the wing was wrong. These were
-)-) on the one-piece struts where the entire strut was welded in a
-)-) single piece, and right and left side were off by the same
-)-) amount. Solution was to cut the top ends off the struts and
-)-) top it with a sleeve (purchased from Zenith--in my humble
-)-) opinion they should have provided it at no charge) that was
-)-) free to rotate to the correct angle, then drill and bolt it in
-)-) place. From what I understand, Zenith subsequently went back
-)-) to providing 2-piece struts for the 701s to avoid this problem.
-)-) Check the 701 archives for details. II'm surprised to hear
-)-) they are back to one-piece in the 750, but if the problem is
-)-) the same, the solution probably is too...
-)-) John
-)-) CH701 95% done, Olathe, KS
-)-) " target="_blank">http://www.matronics.com/Navigator?Zenith750-
-)-) List tp://forums.matronics.com
-)-) _blank">http://www.matronics.com/contribution
-) http://www.matronics.com/contribution _-
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
CDNCH701
Posted: Sat Oct 30, 2010 9:03 am Post subject: Zenith750-List Digest: 1 Msgs - 10/26/10 (750 front strut p |
Thanks Ken...
What is the wall thickness... it seems to be very important?
-) Front is 31.8 X 79.4Rear is 25.4 X 62
-) On Sat, Oct 30, 2010 at 8:24 AM, cdnch701 wrote:
-)-) Hey ken...
-)-) What size is the streamlined aluminum tubing... looking at
-)-) using for my 701 Ron
-)-) 750 struts consist of a length of streamlined aluminum tubing,
-)-) and welded steel fittings that slide into each end.
-)-) On Sat, Oct 30, 2010 at 5:18 AM, John Flavin
-)-) John
-)-) http://www.matronics.com/contribution _-
-)-) st"
-)-) target="_blank">http://www.matronics.com/Navigator?Zenith750-
-)-) List =========== http://forums.matronics.com =========== le,
-)-) List Admin.
-)-) ="_blank">http://www.matronics.com/contribution ===========
kenryan
Posted: Sat Oct 30, 2010 11:50 am Post subject: Zenith750-List Digest: 1 Msgs - 10/26/10 (750 front strut p |
The wall thickness is not constant. The struts are extruded and the ends are thicker than the midsection.
On Sat, Oct 30, 2010 at 9:01 AM, cdnch701 <infow(at)mts.net (infow(at)mts.net)> wrote:
[quote]--> Zenith750-List message posted by: cdnch701 <infow(at)mts.net (infow(at)mts.net)>
Thanks Ken...
-)-) --> Zenith750-List message posted by: cdnch701
-)-) Hey ken...
-)-) John
-)-) st"
-)-) List Admin.
st" target="_blank">http://www.matronics.com/Navigator?Zenith750-List
le, List Admin.
