Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Tue Nov 16, 2010 7:56 am Post subject: windscreen air |
Graeme,
I followed the others and installed a ~2” computer fan aligned in the middle of the port seat andthree inches back from the instrument panel front to whisk away heat from my Dynon screen AND hopefully prevent/overcome misting. Easy, simple, switched and hopefully effective.
Cheers, Ferg [quote][b]
rampil
Posted: Tue Nov 16, 2010 10:26 am Post subject: Re: windscreen air |
I would wait for people actually flying with these fans in condensing
or overheating conditions to report the result of their use before deciding what to do.
After a very warm summer in my neck of the woods, I installed a fan
over my BMA EFIS into a louver pointed at the plexi.
At best, it prolongs the time to EFIS internal temp of 145F by about 15%
meaning from (out of the sun 90F) to 145F flying in sun now takes
about 30 min instead of 25 min. The BMA displays internal temp and shuts
off at 153 or so. Lucky, in the soup it is never that warm!
To be a useful amount of cooling air in my glass panel system, I am
looking at a straight dump of an outside air vent into the panel on the hottest days to be effective given the IR energy and electric load into the panel. All these pretty little fan setups may work fine on a sunny day
in Alaska but not Lakeland Florida.
kheindl(at)msn.com Guest
Posted: Tue Nov 16, 2010 10:34 am Post subject: windscreen air |
Is mist on the windscreen really a problem ? I am asking because I never noticed any on mine.
Cheers,
Karl
Subject: windscreen air
Date: Tue, 16 Nov 2010 10:51:01 -0500
Message body
Graeme,
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
Posted: Tue Nov 16, 2010 10:51 am Post subject: windscreen air |
| Quote: | All these pretty little fan setups may work fine on a sunny day in
To All (of those of us who are flying)...
Still being just a builder, I'd love to hear more on this subject. My
understanding is there are two separate issues...the first being the
ability to blow some warm air on the windshield in order to de-mist,
and the second being the ability to cool the avionics.
Perhaps the little fans can't do both...(?)
Fred
rampil
Posted: Tue Nov 16, 2010 5:45 pm Post subject: Re: windscreen air |
Hi Fred,
Its all a question of degree!
It is a question of moving heat from on place to another. I don't
think the fans would ever need to clear the screen and remove
excess heat from the panel at the same time. How cold is the screen
below dew point, how many calories needed to warm it above dew point
versus how many calories are sucked out, cooling the outside of the
screen via the airstream?
How many calories need to be pulled out of the panel per minute to
match or exceed the IR load dumped into it from the sun.
Either way air does not carry many calories per cubic foot, so you
need to move lots of them
Posted: Tue Nov 16, 2010 6:12 pm Post subject: windscreen air |
On Nov 16, 2010, at 5:45 PM, rampil wrote:
| Quote: | How many calories need to be pulled out of the panel per minute to
Hi Ira...you're gettin beyond my bandwidth...in your previous post, it
seemed to me that your fan installation was for avionics cooling, and
I surmised that you achieved but modest improvement.
Do you ever encounter windshield fogging or misting, and if so, what
have you done or plan to do to alleviate it? (I take it you're not
expecting your fan to do very much.)
Fred
gholland(at)content-strea Guest
Posted: Tue Nov 16, 2010 9:28 pm Post subject: windscreen air |
Fred
Here in UK I have experienced windscreen misting in two different Europa's.
When I built mine I was conscious that air needed extracting through the
rear on panel area to reduce by removing some warmer air created by the
various panel systems. At the same time it occurred to me and at least one
significant other (Paddy!) that it could prove useful if the extraction fans
blew across face of front screen. It did prove to be the case and to work,
certainly within a 5-10 minute start up and taxi cycle.
The side windows are not reached by the fans airflow and they still remain
misted and have to be wiped with absorbent cloth to remove that moisture.
Both Aircraft had overhead Air Vents using flip up air dam in cabin roof.
That proves useful but mainly to reduce inside temperature in summer. It
works very well once underway. I also added warm air system and that too
added to cabin comfort in winter and reduce internal misting.
In climates such as UK in winter with a range between -5C and 15C and a
range of humidity on any day from September to April, misting is a feature
of the Europa cabin and certainly needs addressing. Take off in IMC just due
to condensation is not an experience I personally need! The Cabin clears
after a few minutes if any residual misting left in corner areas due to
natural leaked airflow in fuselage. Sorry to ramble but in short. Fit Fans
if you can with a switched supply and those using EXPBus can also easily
control speed of Fans. These Computer Fans are quiet and certainly produce
some good airflow.
Regardless of theories it worked for me!
I now fly an open cockpit aircraft and even here my bloody goggles sometimes
mist up. Local comment is that my flying improves significantly during these
periods!
In the words of Oscar Wilde....Demist or be damned!
Yes I have just taken my pills!
Gerry
Gerry Holland
07808 402404
gholland(at)content-stream.co.uk
Based at White Ox Mead, Near Bath, UK
Posted: Wed Nov 17, 2010 1:41 am Post subject: windscreen air |
Like Ira I have a BMA Efis and a medium sized fan (over passenger footwell)
with a row of holes under pilot windscreen. It works moderately well in
terms of demisting, where I suspect that you only need to warm the air by a
few degrees to have an effect. It does not stop the Efis complaining about
overheating in central Spain in a heatwave (where I experienced air box temp
of 37.4 C/100F). I have found that in such temps the top of the instrument
module which is painted dark blue, gets unpleasantly hot to touch, and
dealing with that factor is probably more important than the internal air
flow. I have a piece of neoprene with one silvered surface which I place on
top in such conditions, but if I was starting again I would consider
building in some insulation over that top surface and also having the fan.
Regards, David Joyce, G-XSDJ
rampil
Posted: Wed Nov 17, 2010 7:18 am Post subject: Re: windscreen air |
Hi Fred,
I have not seen plexi condensation since I install the fan this summer.
Could be the fan or the weather conditions so far.
I speculate, not having actually measured the wind screen temperature, etc,
that the fan could help but it would be slow to effect change.
That is why I keep a Sontara (Dupont) cloth in the cockpit.
It works instantly and does not make noise!
John Wighton
Posted: Wed Nov 17, 2010 9:27 am Post subject: Re: windscreen air |
Hi, What type of Sontara cloth do you use?
I contributed some pictures to a previous thread on the subject of demisting fans - pictures are on my post at http://forums.matronics.com/viewtopic.php?t=74836&highlight=
The fans work really well in the UK, last week it was cold and the entire cockpit misted up. The fans cleared the important front LH screen immediately (l now leave them on permanently).
Life saver.
JW
