rocket manuevers
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
inverteddecathlon(at)hotm
PostPosted: Mon May 01, 2006 7:00 pm    Post subject: rocket manuevers Reply with quote
Could anyone tell me what aerobatic manuevers are permitted in a Rocket ?
I'm told the prop
extension puts excessive force on the crank and wish to know what exactly
you can and cannot
perform without damaging the engine.
Thanks- Craig
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
nwinterest(at)yahoo.com
PostPosted: Mon May 01, 2006 7:49 pm    Post subject: rocket manuevers Reply with quote
It depends on your prop, engine mounts and type of maneuvers. Any "gentleman" aerobatics are fine; These include rolls, loops, cuban eights, inverted flight (with appropriate system). If you have a metal prop and you are doing radical snap rolls or abrupt maneuvers, you might bend the shaft. If you have a composite prop, you can get away with more radical stuff; the prop will absorb some of that energy and not transmit it to the shaft/bearings. But, the aircraft has limits too. It isn't an unlimited type of aircraft. It is build, more or less, for basic aerobatics...maybe a step more.
-Good luck,
Matt
I'm told the prop
you can and cannot
Thanks- Craig
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Jim Anglin
PostPosted: Tue May 02, 2006 7:24 am    Post subject: rocket manuevers Reply with quote
I have never seen an approved list of maneuvers published for any of the =
RV series including the HR II and F 1. All planes are limitied by the =
published airframe G force numbers and any equipment that is installed. =
In the case of the prop most are using on Rockets, the M2YR hub, we are =
limited to 3.8 Gs. There are variables that I am sure someone will =
point out but this is my controlling number. At 62 yrs. and 30 pounds =
overweight I am not interested in unlimited aerobatics, or even =
sportsman for that matter - an occassional roll or loop and I'm done.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
