RV7-List Digest: Silicon dab in elevators - how important i
aurbo(at)ak.net
PostPosted: Wed May 03, 2006 5:46 am    Post subject: RV7-List Digest: Silicon dab in elevators - how important i Reply with quote
Jon,
Don't drill out the elevator, you will likely do more damage than the lack of silicon will cause. If your elevator does crack, and that is only a maybe, then you can fix it later. Build on.
Mike Ice RV-9 fuselage, installing tail wheel
Anchorage, Alaska
ceengland(at)bellsouth.ne
PostPosted: Wed May 03, 2006 6:37 pm    Post subject: RV7-List Digest: Silicon dab in elevators - how important i Reply with quote
Dog67(at)aol.com wrote:
Help!
I'm slowly working my way thru my elevator only to realize i did the final
riviting before I put a dab of silicone or sealant between the stiffeners.
How important is this? Should I drill out all the rivits and do it again?
jon
If you're still worried after the previous posts, try running some of
that 1/4" translucent semi-rigid tubing from the building supply into
the trailing edge from the end. On my elevators, I could slip it in past
the stiffeners. If it will fit in yours, you can force the silicone into
the tubing a couple of inches, insert the tube along the trailing edge a
measured distance to the innermost stiffener, & force the silicone out
with a little compressed air.
Charlie
