First engine start
john.marzulli(at)gmail.co
PostPosted: Wed Jan 12, 2011 11:02 am    Post subject: First engine start Reply with quote
http://marzulliphoto.net/Airplanes/Engine-Start/15418559_HjB2c
The engine ran nice and smooth. The star-up was easy. The Dynon registered the EGT, CHT, oil pressure, ect as expected. The only issue was the RPM adjustment had not been made to the Dynon so the RPMs read about 50% of actual at the crankshaft.
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
bobkat
PostPosted: Wed Jan 12, 2011 1:26 pm    Post subject: First engine start Reply with quote
Way to go John. Mine was the same but the Dynon is easy to set. Mine belched out a puff of smoke on the first firing, probably some engine preservative!
Sent: Wednesday, January 12, 2011 12:57 PM
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Subject: First engine start
John Marzulli
href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
agibeaut
PostPosted: Wed Jan 12, 2011 2:02 pm    Post subject: First engine start Reply with quote
Great news, thanks for the video John. You are still ahead of me on the building and maybe gaining ground. Congrats on the successful engine start.
Art G.
CH701 and 912UL
Erie, IL
Sent: Wed, January 12, 2011 12:57:11 PM
John Marzulli
http://701builder.blogspot.com/
ruruny(at)aol.com
PostPosted: Thu Jan 13, 2011 4:05 pm    Post subject: First engine start Reply with quote
John,
Congratulations, you're getting close! Make sure to start it up once in a while as you finish building.
I let mine sit for quite a few months and the idle mixture circuit clogged up.
Brian
PostPosted: Thu Jan 13, 2011 5:06 pm    Post subject: First engine start Reply with quote
Thanks for the tip! Hopefully it won't be that long from now until I get it flying.
John Marzulli
On Thu, Jan 13, 2011 at 4:02 PM, <ruruny(at)aol.com (ruruny(at)aol.com)> wrote:
John,
Brian
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
ttp://forums.matronics.com
Geoff Heap
PostPosted: Wed Jan 19, 2011 5:16 am    Post subject: Re: First engine start Reply with quote
Ill bet you were watching that Dynon panel like a Hawk. Well done John. The video was nice. I hope to do my rotax first start in a few weeks time. My engine was installed in January 2007. I expect I'll need to do some work on the carbs first.......Geoff
Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons.
