				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Wed Jan 19, 2011 11:37 am    Post subject: Mono undercarriage |   |
				| I am refurbishing some slightly bent bits in my U/C ( bent after an
encounter with an unseen dip, while landing in an unprepared farmer's field)
 and find that the 2 shock absorbers/dampers are pretty much shot. They are
 10+ years/800+ hrs old so may simply be suffering from old age (like the
 pilot!) In looking through the build manual I see that these are described
 as optional. Does anyone have an educated view of the benefits of fitting
 them or not ( you can assume that I shall not be landing in too many
 unprepared fields!)
 Regards, David Joyce, G-XSDJ
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Remi Guerner
				|  Posted: Fri Jan 21, 2011 12:23 am    Post subject: Re: Mono undercarriage |   |
				| Hi David,
 I also found that my dampers were not in good shape after 800 hours. I was tempted to try without them but decided against it as it seems  they also serve as a guide to maintain the rubber block in position.
 Remi Guerner
 F-PGKL
		| Back to top |  |
				|  Posted: Fri Jan 21, 2011 2:39 am    Post subject: Mono undercarriage |   |
				| Remi, Thanks for that. I have been persuaded that it is worth having them
and have been offered a pair by 2 people who converted from mono to trike.
 If you are looking for a cheap set Bob Harrison would no doubt be pleased to
 give you his for  very little. Regards, David
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
