WhirlWind
Posted: Wed Feb 02, 2011 2:33 pm Post subject: Composite V530 Propeller Blades & Spinners |
Hello, this is Patti at Whirl Wind Propellers. I have seen a number of questions regarding the new composite blades and spinner now available for the V530 propellers, so I thought it would be a good idea to post some information on our newest products to this list.
Whirl Wind is now shipping the new composite W530 propeller blades which are a direct replacement for the wood V530 propeller blades as well as the 20" diameter composite spinner that works with either the V530 or W530 blades.
http://www.whirlwindpropellers.com/v530/index.html
W530 Composite Blades
The new WhirlWind W530 all-composite blades are designed to fit the existing V530 propeller hub on M-14P engine powered aircraft. The W530 blades have an updated blade twist distribution, new airfoils and a unique profile to give improved take-off, climb, and cruise performance with smooth quiet operation. The unique Whisper Tip™ scimitar blade planform reduces aerodynamic transonic drag, increases efficiency and reduces prop noise. This means more performance for your airplane, and less noise from the propeller.
The W530 has an increased diameter of 98.5” (250cm) which translates to better climb performance. There is also a 6 lbs weight savings with the new W530 blades.
The picture below shows the new W530 blades installed on Ryan Carroll's Yak 52. Ryan has done some test flying to compare the V530 and W530 blade performance. He is on this list and would probably be a good resource to answer questions regarding performance or installation of the W530 blades.
New W530
Diameter: 250 cm (98.5 inches)
Construction: Thermo-set Aerospace Graphite composite
Leading Edge: Flush bond Nickel
Weight: 15.5 lbs
(6 lbs savings per set)
Original Wood V530
Diameter: 240 cm (94.5 inches)
Construction: Wood
Leading Edge: Riveted Multi-piece Stainless
Weight: 18.5 lbs
Spinners
We also have a new composite 20" diameter spinner that will turn your trainer into a fighter. The spinner comes with front & rear bulkheads installed, nutplates installed. The spinner will arrive fitted & trimmed with a primer coat ready for paint. The current price is $1,500 USD plus shipping.
Please feel welcome to call or email me with any questions and I would be happy to talk with you.
Where to Buy
The W530 composite blades and the 20" Spinner can be purchased from:
M-14P.com
and
WhirlWindPropellers.com
Current Pricing*
W530 Blades: $6,000 per set
20" Spinner: $1,500
*All prices USD,
**All prices are subject to change without notice,
*** Prices do not include shipping cost
Sincerely,
Patti
wwpdc(at)whirlwindpropellers.com
619-562-3725
| Description: |
| W530 Composite blades installed on Ryan Carroll's Yak. |
| Filesize: |
517.14 KB |
| Viewed: |
5850 Time(s) |
| Description: |
| Drawing of 20" V530 Spinner |
| Filesize: |
169.02 KB |
| Viewed: |
5850 Time(s) |
| Description: |
| 20" Composite V530 Spinner |
| Filesize: |
756.87 KB |
| Viewed: |
5850 Time(s) |
HawkerPilot2015
Posted: Thu Feb 03, 2011 8:50 am Post subject: Re: Composite V530 Propeller Blades & Spinners |
I had Whirlwind refurbed blades on my -50 and they were beautiful!
Personally, in this economy, I would buy something made here in the United States by American workers.
