O-235
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV3-List
Jim Anglin
PostPosted: Fri Apr 28, 2006 9:29 am    Post subject: O-235 Reply with quote
Does anyone know of an RV3 flying with the O235L2C (or any for that =
matter)? I am on the verge of going this route but one person, an IA =
that specializes in Grummans, told me he doesn't like these engines, =
primarily because they have solid lifters. He didn't mention any other =
specifics, just a general dislike for these engines. Is he correct and =
what is the general consensus of this group?
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
- The Matronics RV3-List Email Forum -
http://www.matronics.com/Navigator?RV3-List
Jim Anglin
HR II N144HR
jconners(at)dot.state.nv.
PostPosted: Fri Apr 28, 2006 9:41 am    Post subject: O-235 Reply with quote
The L2C has a 2400 TBO. This engine was designed for the newer fuels;
however, if you do an extended dead stick landing, then the no power
approach will result in foiling the lower plugs.
The are numerous publications reference the lifters and they should be
consulted as to the pros and cons.
I own/fly the O-235 L2C engine.
randy(at)romeolima.com
PostPosted: Fri Apr 28, 2006 2:14 pm    Post subject: O-235 Reply with quote
Jim Anglin
HR II N144HR
The last RV-3 that Van's had flying, which is now mothballed in Van's home
hangar, had an O-235 installed. They took that engine out to put in the
RV-9A prototype. Don't know about the solid lifters but that should be easy
to find out.
Randy Lervold
www.rv-3.com
smokyray(at)yahoo.com
PostPosted: Fri Apr 28, 2006 5:09 pm    Post subject: O-235 Reply with quote
Hi Randy,
The very first RV I flew was an 0-235 powered RV3. It had a very small battery and photoelectric cell charging system, no starter and very basic panel and flew better than my current 170 HP RV4. 0-235's can be bought for under 5-7K low time ready to fly and can run autogas. The bottom line is weight, they weigh 50 lb's less than an 0-320. With the proper flow benching, sparrow-hawk pistons (115 HP) and a good prop you would have a very fuel efficient, lightweight fun airplane for high gas price economy...
my 2 cents...
RR
Jim Anglin
HR II N144HR
to find out.
Randy Lervold
www.rv-3.com
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1&cent;/min.
Jim Anglin
PostPosted: Sat Apr 29, 2006 5:20 am    Post subject: O-235 Reply with quote
Great response - I assume that everyone likes this engine because there =
were no negatives posted. Those of you that flew behind this engine: =
how often do the valves need to be adjusted and how much work is it?
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
jany77(at)sbcglobal.net
PostPosted: Sat Apr 29, 2006 10:08 am    Post subject: O-235 Reply with quote
im curently flying this engine in c-152 works and sounds really good i have same engine for my rv-3 which im building just because the weight there is enough power ,with high compression pistons and good exhaust you can get as much as 130 hp also good propeller helps here that just my opinion i have some back round in conversation automobile engines for ultralight all what i sad about o-235 will works
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
PostPosted: Sun Apr 30, 2006 6:03 am    Post subject: O-235 Reply with quote
Jan, I think the Lycoming book requires the valves to be adjusted every 250 hours. The reason they went with solid lifters was the same reason the racecar guys all have solid lifters, power response. BTW, all BMW's used to have solid lifters (some still do) it's not that big of a deal to keep them adjusted and actually adds performance.
See ya!
RR
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
How low will we go? Check out Yahoo! Messengers low PC-to-Phone call rates.
PostPosted: Sun Apr 30, 2006 7:04 pm    Post subject: O-235 Reply with quote
yes that engine is good even if they have to be adjust every 250 hours how many guys fly 250 hours a year so you can check them every annual that is what im doing every year thanks rob
See ya!
RR
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
atomic
PostPosted: Wed May 03, 2006 4:24 am    Post subject: Re: O-235 Reply with quote
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Hello Jim. Which propeller do you think is better combination RV-3/O-235?
Mario.
PostPosted: Wed May 03, 2006 7:53 am    Post subject: O-235 Reply with quote
Craig Catto www.cattopropellers.com makes a great prop for the 0-235 powered Long EZ. Give him a call...
Rob Ray
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Mario.
http://forums.matronics.com/viewtopic.php?p=32504#32504
Yahoo! Mail goes everywhere you do. Get it on your phone.
Jim Anglin
PostPosted: Thu May 04, 2006 7:51 am    Post subject: O-235 Reply with quote
Hello Jim. Which propeller do you think is better >combination =
RV-3/O-235?
=20
> Mario.
I haven't gotten that far Mario - maybe someone else can help. Van's =
sells this engine (for $21,000) so maybe they know.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
Jim Anglin
PostPosted: Thu May 04, 2006 7:55 am    Post subject: O-235 Reply with quote
>Time: 08:53:53 AM PST US=20
>From: rob ray <smokyray(at)yahoo.com>=20
>Subject: Re: O-235=20
=20
=20
>Craig Catto www.cattopropellers.com makes a great >prop for the =
=20
>Rob Ray
I have seen longezes fly - I want better performance than that: 2000 ft =
ground roll and 200 fpm climb. <G>
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
PostPosted: Thu May 04, 2006 10:25 am    Post subject: O-235 Reply with quote
Jim,
You're kidding, right? I'm from Alabama but even I know that comparing Long Ez's to RV's in performance is like comparing the F16 I fly for a living to your Harmon Rocket...totally different.
LongEZ's hug the ground and climb poorly because of their wing/canard, not their prop...
Craig makes props for ALL experimental applications, he just got famous building LongEZ props. In fact, one of his props is on the USAF Predator drone prototype. He is revered in the EZ community as several EZ's have had parts fall off inflight and go through his prop with little damage and all flew home. I doubt many wood props would survive and even a Hartzell might be challenged. I only recommended his product as I have extensive experience with it on several RV's, period.
Craigs props run smooth, are strong and reasonably priced, and he guarantees their performance. What more can you ask for?
Click on the link .....
www.cattoprops.com
Rob Ray
Archive all you want...
=20
=20
=20
Rob Ray
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
PostPosted: Fri May 05, 2006 7:57 am    Post subject: O-235 Reply with quote
Take it easy - didn't see the <G> didja. I know all the differences =
between the two - guess I'll save the humor for a less sensitive =
audience.
Just out of curiosity - do you own an RV?
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
PostPosted: Fri May 05, 2006 9:16 am    Post subject: O-235 Reply with quote
No worries Jim, you never know who you're dealing with out there these days people wise...I had a guy who owned an RV for sale last week tell me about it's laminar flow wing design "Like a Mooney"...hmmm.
Anyway, I own an RV4 and 1/2 of an RV-6(under const). I have put 1400 hours on the 4 in 10 years. I started out in RV's flying an RV3...I want another one...good luck with the 0-235 powered version, the one I flew was set up that way and flew great.
see ya!
RR
Take it easy - didn't see the didja. I know all the differences =
audience.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Blab-away for as little as 1/min. Make PC-to-Phone Calls using Yahoo! Messenger with Voice.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV3-List All times are GMT - 8 Hours
