jconners(at)dot.state.nv. Guest
Posted: Thu Feb 17, 2011 9:11 am Post subject: [QUAR] Re: DUST COVER |
And something easily removable…having work access to ‘behind the panel’ from the ‘top’ has been important during the last 10 years flying N94K.
Jer
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of ALFRED ROSA
Sent: Thursday, February 17, 2011 8:18 AM
To: kis-list(at)matronics.com
Subject: [QUAR] Re: DUST COVER
Importance: Low
THANKS ALL FOR THE TIPS. There's many ways to skin this cat. I think I will cut one out of sheet metal and bend it to shape. then do layups using the metal as a mould. Then surface the whole thing with 1/4" soft foam and cover with beige vinyl that I'm using for the interior.
Al
On Wed, Feb 16, 2011 at 10:30 AM, ted <teds532(at)wk.net (teds532(at)wk.net)> wrote:
I MADE MY DUST COVER WITH 1/4 INCH HARDWARE CLOTH LARGER THEN NEEDED.CUT TO SIZE LATER,COVERED WITH DUCT TAPE THEN WITH PEELPLY,TWO LAYERS OF FIBERGLASS,ONE LAYER OF CARBON FIBER THEN PUT IT ON TOP OF THE CONTROL PANEL AND USED CLEECO CLIPS AND WOOD BRACES TO HOLD IT IN PLACE UNTILL DRY.ADDED 1/4 INCH FOAM .ADDED EXTRA FOAM ON EDGE AT CONTROL PANEL.
Quote: | et="_blank">http://www.matronics.com/Navigator?KIS-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution |
Quote: | </========================[/b] | [/b]http://www.matronics.com/Navigator?KIS-List</======================== [/quote]012<://www.matronics.com/contribution">http://www.matronics.com/contribution[/b] [/quote]3
This communication, including any attachments, may contain confidential information and is intended only for the individual or entity to whom it is addressed. Any review, dissemination or copying of this communication by anyone other than the intended recipient is strictly prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and delete all copies of the original message. ญญ [quote][b]
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
