Prop Governers
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
pcondon(at)mitre.org
PostPosted: Sat May 06, 2006 8:40 am    Post subject: Prop Governers Reply with quote
My -540-C4B5 has a 1/4 inch or so spacer between the case and the
governor. Without this spacer, the drive gear preload would be amiss.
Also, the gaskets need care when installing to get the proper ones due
to oil hole alignment. I would recommend a prop shop rebuild the
governor. There are oil orifices and passages within the governor and
the repair facility can tweak the governor and "match" your speed
(Rocket) and Prop. Also, the proper gaskets can be supplied by the
repair facility...they know which ones to use on both sides of the
spacer.......
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
