ftyoder(at)yoderbuilt.com Guest
Posted: Thu Mar 03, 2011 7:07 pm Post subject: IO-240B With the 15V 60A TCM altinator |
FYI,
I was fly a couple weeks ago and lost The Alt.
I determined that the Alt. was not producing power and removed it. I am sure Cont. could have made that job harder if they tried.
I found the Alt. was ok but the Alt. Drive Coupling Assembly (P/N 635796) was broken, the Lord rubber mount came loose from the ss shroud. Better if the Alt was bad.
The bad news is that Cont. wants $2077.00 for this part, no, the engine is not included!
The not so bad news is that Drake rebuilds them and they can be had for $600.00 to $900.00, with a good core.
I only had a little over 400 hrs. on the engine. I had to remove a Slick Mag to get the Alt. out, so I had the mag 500 hr service done. New points and replaced a bad gear. So for only a $1000.00 + I now have lots of amps & volts.
Hope you have the "good" ones!
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Keith.Miller(at)esa.int Guest
Posted: Fri Mar 04, 2011 12:25 am Post subject: IO-240B With the 15V 60A TCM altinator |
that is not what I want to hear , my IO240B is just coming up to 400hrs ,
but thanks for sharing it with us anyway , at least the shock will be less
when it eventually happens to mine
Keith
To: <kis-list(at)matronics.com>
Date: 04/03/2011 04:09
Subject: IO-240B With the 15V 60A TCM altinator
Sent by: owner-kis-list-server(at)matronics.com
FYI,
Alt was bad.
not included!
volts.
John Jackson
Joined: 27 Mar 2010 Posts: 14 Location: Shrewsbury, UK
Posted: Fri Mar 04, 2011 2:10 am Post subject: IO-240B With the 15V 60A TCM altinator |
Keith. My alternator drive coupling failed after about 50 hours. I put it down to kickback on startup and had the mags retarded a little. The original coupling was elastomeric and had failed in sheer. I managed to locate an alternative style that was mechanical but has rubber inserts for shock absorbtion. I got it second hand and from memory only cost about £100. John
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
Keith.Miller(at)esa.int wrote:[quote] --> KIS-List message posted by: Keith.Miller(at)esa.int Tim that is not what I want to hear , my IO240B is just coming up to 400hrs , but thanks for sharing it with us anyway , at least the shock will be less when it eventually happens to mine Keith From: "F. Tim Yoder" <ftyoder(at)yoderbuilt.com> To: <kis-list(at)matronics.com> Date: 04/03/2011 04:09 Subject: IO-240B With the 15V 60A TCM altinator Sent by: owner-kis-list-server(at)matronics.com FYI, I was fly a couple weeks ago and lost The Alt. I determined that the Alt. was not producing power and removed it. I am sure Cont. could have made that job harder if they tried. I found the Alt. was ok but the Alt. Drive Coupling Assembly (P/N 635796) was broken, the Lord rubber mount came loose from the ss shroud. Better if the Alt was bad. The bad news is that Cont. wants $2077.00 for this part, no, the engine is not included! The not so bad news is that Drake rebuilds them and they can be had for $600.00 to $900.00, with a good core. I only had a little over 400 hrs. on the engine. I had to remove a Slick Mag to get the Alt. out, so I had the mag 500 hr service done. New points and replaced a bad gear. So for only a $1000.00 + I now have lots of amps & volts. Hope you have the "good" ones! [quote][b]
Posted: Fri Mar 04, 2011 7:50 am Post subject: IO-240B With the 15V 60A TCM altinator |
John, Do you have part no's for the replacement parts?
Thanks, Tim
John Jackson
Posted: Fri Mar 04, 2011 9:47 am Post subject: IO-240B With the 15V 60A TCM altinator |
Tim.
I thought it lasted 50 hours, after checking the engine logbook it actually lasted 225 hours! Shows how quickly the pain dulls after the passage of time.
I removed part no. 635796 and replaced it with p/ns 531325, 530407, 632050, 653982 and 653983.
"F. Tim Yoder" <ftyoder(at)yoderbuilt.com> wrote:[quote] John, Do you have part no's for the replacement parts?
Thanks, Tim
Posted: Fri Mar 04, 2011 9:58 am Post subject: IO-240B With the 15V 60A TCM altinator |
Thank you John, I will keep that info on file, as I am sure others will.
