(now) P-Mags
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
klwerner(at)comcast.net
PostPosted: Wed Mar 09, 2011 10:36 am    Post subject: (now) P-Mags Reply with quote
Hi Harry,
I think running a P-Mag or one LSE in addition to one Magneto would be a conservative solution. However, I would feel pretty darn safe behind DUAL LSE's or P-Mags, as long as they are powered individually... Electronics have been around for a while, and they can be made nearly fail safe. Magneto's are certainly not fail safe either. Use whatever lets you sleep at night Wink
Konrad
On Mar 9, 2011, at 10:44 AM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
[quote]HI Konrad,
Well, the evidence seems to be accumulating that they have. More and more of them are in use in RV's in my area, KLVK, and so far it looks like they may have worked through those early problems. I remain somewhat cautious but thinking about starting with one and see how it goes.
Harry Crosby
RV-6 N16CX, 805 hours
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
pmnewlon
PostPosted: Wed Mar 09, 2011 11:13 am    Post subject: (now) P-Mags Reply with quote
FWIW - I learned something by reading the EmagAir manual. The Pmag, with the built-in alternator, self-powers at all times unless the RPM of the engine falls below the threshold where it can do so. Thus, instead of being concerned about a continuous 1A drain from the power source (battery in the case of an alternator out condition), as long as you are in cruise condition the mags are not a factor. I agree with the 'individually powered' statement, and am adding a small 7AH battery to my system, will power one mag from the main battery and the other from the backup. (see AEC diagrams http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z10-8A1.pdf http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z10-8A2.pdf ) Unfortunately in my case I can't fit a backup alternator/dynamo so will have two batteries and a single alternator.[quote]---
PostPosted: Wed Mar 09, 2011 11:45 am    Post subject: (now) P-Mags Reply with quote
Phil,
You can't add the little SD-8 alternator (by B&C) on your vacuum pad? I think that little alternator is just perfect either as a back up. But then, the SD-8 is actully all that I am planning on using on my future airplane (which will not have much electric drain either)... But then, I also plan on a small 5-7AH (Ignition only!) battery just in case. That should do the trick and is light weight too.
Konrad
On Mar 9, 2011, at 12:10 PM, Phil N wrote:
[quote]FWIW - I learned something by reading the EmagAir manual. The Pmag, with the built-in alternator, self-powers at all times unless the RPM of the engine falls below the threshold where it can do so. Thus, instead of being concerned about a continuous 1A drain from the power source (battery in the case of an alternator out condition), as long as you are in cruise condition the mags are not a factor. I agree with the 'individually powered' statement, and am adding a small 7AH battery to my system, will power one mag from the main battery and the other from the backup. (see AEC diagrams http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z10-8A1.pdfhttp://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z10-8A2.pdf ) Unfortunately in my case I can't fit a backup alternator/dynamo so will have two batteries and a single alternator.
[quote]---
pmnewlon
PostPosted: Wed Mar 09, 2011 12:39 pm    Post subject: (now) P-Mags Reply with quote
Tried, it won't fit - bumps engine mount. I have an O320 narrow deck (conical mount). It will fit on the O360 wide deck for certain as I talked to several people that have that config and are running the SD8> You can't add the little SD-8 alternator (by B&C) on your vacuum pad? I think that little alternator is just perfect either as a back up. But then, the SD-8 is actully all that I am planning on using on my future airplane (which will not have much electric drain either)... But then, I also plan on a small 5-7AH (Ignition only!) battery just in case. That should do the trick and is light weight too.
PostPosted: Wed Mar 09, 2011 12:51 pm    Post subject: (now) P-Mags Reply with quote
Bummer... but then a small dedicated backup battery will do the trick to provide enough ignition energy to find a suitable landing spot in case of a total electrical failure (?). Unless things go really wrong, remember that you still have the main battery too for that same purpose Wink
Konrad
On Mar 9, 2011, at 1:36 PM, Phil N wrote:
[quote]Tried, it won't fit - bumps engine mount. I have an O320 narrow deck (conical mount). It will fit on the O360 wide deck for certain as I talked to several people that have that config and are running the SD8
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
PostPosted: Wed Mar 09, 2011 6:09 pm    Post subject: (now) P-Mags Reply with quote
Konrad,
I agree with you about electronics but my understanding is that most if not all of the P-Mag/E-Mag early teething problems were actually mechanical in nature. I may be wrong.
Harry Crosby
Robin(at)PaintTheWeb.com
PostPosted: Wed Mar 09, 2011 7:24 pm    Post subject: (now) P-Mags Reply with quote
As described to me there was a magnet or something held with epoxy that when the unit became hot moved, shifted or in some way changed the function of the unit to then fire something like 180 degrees out of phase.
This is how it was described to me.
Robin
From: owner-rv6-list-server(at)matronics.com (owner-rv6-list-server(at)matronics.com) [mailto:owner-rv6-list-server(at)matronics.com (owner-rv6-list-server(at)matronics.com)] On Behalf Of HCRV6(at)comcast.net (HCRV6(at)comcast.net)
Sent: Wednesday, March 09, 2011 6:07 PM
To: rv6-list(at)matronics.com (rv6-list(at)matronics.com)
Subject: Re: Re: (now) P-Mags
Konrad,
Harry Crosby
PostPosted: Wed Mar 09, 2011 10:40 pm    Post subject: (now) P-Mags Reply with quote
Dear Harry,
I don't remember anymore what kind of problems they had back then, but I think they took care of whatever it was by now... There won't be any progress in life unless there are risk takers who'd go the extra mile to come up with something new Smile
Konrad
On Mar 9, 2011, at 7:06 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
[quote]Konrad,
Harry Crosby
dan.pat.b(at)gmail.com
PostPosted: Thu Mar 10, 2011 7:06 am    Post subject: (now) P-Mags Reply with quote
Good Morning:For what it's worth: I fly with dual E-Mag Electronic Ignition units on my Mattituck TMX IO-360 equipped RV-7A.  I have 222 hours on the engine since new and have never flown with anything other than the E-Mags; so I have no basis for comparison with any other system.  I have never had even the hint of a problem and have no complaints.  They're also easy to time.  I do a lot of x/c flying and find that, leaned to 50 degrees lean of peak, fuel burn at 2300 rpm is about  7.5 gph.
Before first flight on my a/c back in Aug 09 there was a recall of the units due to a mechanical issue - I don't recall specifics but it had something to do with a faulty set screw arrangement.  E-Mag modified/ fixed the units at no cost and I'm not aware of any issues with the modified units.
I fly with aviation spark plugs and think I'd be a little nervous flying with auto plugs.  Are automotive plugs able to tolerate the increased ignition temps of P Mags / E Mags?
Dan Bergeron
RV-7A - N307TB
222 hours since first flight
on  Aug 6, 2009
On Thu, Mar 10, 2011 at 1:35 AM, Konrad/Conny <klwerner(at)comcast.net (klwerner(at)comcast.net)> wrote:
[quote]Dear Harry,
Konrad
[quote] Konrad,
Harry Crosby
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
