Posted: Tue Mar 15, 2011 3:49 pm Post subject: Balance weights on Hartzell CS prop hub |
A close examination of my (unused, unmounted) Hartzell prop hub, I see 2
screws safety wired together on the hubs, near where the prop shafts are
mounted. What's strange is that there are 8 threaded screw holes, 2
pair at each prop shaft. But only 2 of the 8 are in place and safety wired.
In the Owner's manual, they are called 'balance weights'. In one
drawing it looks like a plate of some sort might be mounted under the
screws. One other diagram 'suggests' safety wire. Otherwise, I can
find no reference to them.
Anyone know anything about this?
I know this isn't enough information to easily picture this but I'm
thinking someone is familiar enough to know what I'm talking about.
It's weird to see 8 holes and only 2 screws.
Bill Watson
Posted: Tue Mar 15, 2011 4:04 pm Post subject: Balance weights on Hartzell CS prop hub |
The screws hold balance weights, which are plates that mount under pairs
of screws. The two screws you see are part of the 'weight' ..... but no
plates were needed. meaning that the initial assembly and static balance
were almost spot on.
I once balanced a prop on a homebuilt that the owner had taken apart
after a gear-up landing ...... his third. He 'straightened' the bent
blades with a 5 Lb maul (already spent too much on new blades!),
reassembled, and when he did he put all the weights on one blade ......
on one side! The prop stayed together longer than the owner. I was amazed.
Linn
On 3/15/2011 7:44 PM, Bill Watson wrote:
2 screws safety wired together on the hubs, near where the prop shafts
are mounted. What's strange is that there are 8 threaded screw holes,
2 pair at each prop shaft. But only 2 of the 8 are in place and
safety wired.
Bill Watson
Posted: Tue Mar 15, 2011 6:27 pm Post subject: Balance weights on Hartzell CS prop hub |
That's how I interpreted it, but in the beginning, didn't have a clue.
Thanks, that's what I wanted to hear.
Bill
On 3/15/2011 7:57 PM, Linn Walters wrote:
pairs of screws. The two screws you see are part of the 'weight'
..... but no plates were needed. meaning that the initial assembly and
static balance were almost spot on.
...... on one side! The prop stayed together longer than the owner.
I was amazed.
Linn
> see 2 screws safety wired together on the hubs, near where the prop
> shafts are mounted. What's strange is that there are 8 threaded
> screw holes, 2 pair at each prop shaft. But only 2 of the 8 are in
> Bill Watson
drfred(at)suddenlinkmail. Guest
Posted: Wed Mar 16, 2011 6:47 am Post subject: Balance weights on Hartzell CS prop hub |
Bill,
I had my prop balanced after about 150 hrs. The weights actually went
in the holes on the flywheel. No more than a AN3 screw and a couple of
washers. You shouldn't need to do anything else with the prop itself.
Dr Fred.
On 3/15/2011 6:44 PM, Bill Watson wrote:
safety wired.
Bill Watson
Posted: Wed Mar 16, 2011 7:27 am Post subject: Balance weights on Hartzell CS prop hub |
So it seems that the factory does some balancing of the new prop itself
(per Linn).
Then if the prop installation is balanced by whatever means, weights may
be applied to the engine flywheel.
Thanks Dr Fred.
On 3/16/2011 10:41 AM, Fred Williams, M.D. wrote:
<drfred(at)suddenlinkmail.com>
Bill,
of washers. You shouldn't need to do anything else with the prop itself.
Dr Fred.
Kellym
Posted: Wed Mar 16, 2011 7:38 am Post subject: Balance weights on Hartzell CS prop hub |
What you are discussing is the difference between static balance, which
is done by factory or any prop shop when they service a prop which is
simply having prop balanced end to end about the center point; and
dynamic balance that is done on the aircraft with the engine running,
and will be different for every engine, for any difference in prop
clocking if it is changeable. A prop must have proper static balance
before you will be able to effectively do a dynamic balance.
On 3/16/2011 8:23 AM, Bill Watson wrote:
itself (per Linn).
may be applied to the engine flywheel.
Thanks Dr Fred.
> Bill,
> went in the holes on the flywheel. No more than a AN3 screw and a
> couple of washers. You shouldn't need to do anything else with the
> prop itself.
> Dr Fred.
KCHD |
Posted: Wed Mar 16, 2011 7:45 am Post subject: Balance weights on Hartzell CS prop hub |
As was mentioned, the manufacturer (and/or prop shop) will do a balance on the prop before delivery, but the weights added to the ring gear are for a dynamic balance, which balances the prop as mounted with the spinner and all of that stuff on it.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Mar 16, 2011, at 10:41 AM, Fred Williams, M.D. wrote:
Bill,
I had my prop balanced after about 150 hrs. The weights actually went in the holes on the flywheel. No more than a AN3 screw and a couple of washers. You shouldn't need to do anything else with the prop itself.
Dr Fred.
> A close examination of my (unused, unmounted) Hartzell prop hub, I see 2 screws safety wired together on the hubs, near where the prop shafts are mounted. What's strange is that there are 8 threaded screw holes, 2 pair at each prop shaft. But only 2 of the 8 are in place and safety wired.
> In the Owner's manual, they are called 'balance weights'. In one drawing it looks like a plate of some sort might be mounted under the screws. One other diagram 'suggests' safety wire. Otherwise, I can find no reference to them.
> I know this isn't enough information to easily picture this but I'm thinking someone is familiar enough to know what I'm talking about. It's weird to see 8 holes and only 2 screws.
> Bill Watson
Neal.George(at)hurlburt.a Guest
Posted: Wed Mar 16, 2011 9:09 am Post subject: Balance weights on Hartzell CS prop hub |
True as far as it goes.
Not every engine that this prop will fit is equipped with a flywheel in
which to mount balance weights, and not everybody thinks the spinner
back-plate is the best place to be poking holes for balance bolts.
Neal
jjessen01
Posted: Wed Mar 16, 2011 10:03 am Post subject: Balance weights on Hartzell CS prop hub |
Does doing a static balance apply to all props, including wood?
John J
Posted: Wed Mar 16, 2011 11:01 am Post subject: Balance weights on Hartzell CS prop hub |
Putting balance weights on the flywheel will refine the balance done
with the prop weights, which is a static balance. I recommend everyone
get their prop balanced to reduce vibration which lessens wear/tear on
airframes and pilots alike. Put a clear glass of water on the
glareshield and see how big the ripples get. Do it again after the
balance job. See the results. Engine/prop vibrations are very
subjective when taken through the seat of your pants.
Linn
Bill,
Dr Fred.
> Bill Watson
Posted: Wed Mar 16, 2011 11:16 am Post subject: Balance weights on Hartzell CS prop hub |
My experience says it's harder to get a good balance with a wooden prop
because it flexes more than a metal one. It can be done, just takes
longer, and you really need to know what RPM you cruise at most often as
RPM will make a difference. There are lots of other 'things' that make
a dynamic balance job harder too.
Linn
On 3/16/2011 2:00 PM, John J wrote:
John J
acsjohn
Posted: Fri Mar 18, 2011 2:35 pm Post subject: Balance weights on Hartzell CS prop hub |
Hi Bill, indeed they are balance weights and depending upon the static balance horizontally and/or vertically are applied to the various screw locations to affect horizontal or vertical balance in various numbers. If you don't have many, you most likely have a well balanced prop statically. Dynamically is a different thing and a good thing to do when early in your flying phase. Balance weights will then be added most likely to the spinner backplate in addition. Also make sure the lockwire running between the screws isn't capable of sawing a groove in the blade as it moves during constant speeding. John 40315
VH-XIO 50hrs
On Wed, Mar 16, 2011 at 9:44 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Bill Watson
http://forums.matronics.com
le, List Admin.
ACS Propeller
John Dunne
Managing Director
www.acspropeller.com.au
Aviation Component Services (Qld) Pty Ltd.
T/A "ACS Propeller"
Archerfield Airport, Queensland Australia
PH: 61 7 3274 4500 FAX: 61 7 3274 4010
acsjohn
Posted: Fri Mar 18, 2011 3:25 pm Post subject: Balance weights on Hartzell CS prop hub |
Apologies to Bill and the list for rudely leaving my calling card on my post!John 40315 VH-XIO
Bill Watson
Posted: Fri Mar 18, 2011 3:36 pm Post subject: Balance weights on Hartzell CS prop hub |
On 3/18/2011 6:31 PM, John Dunne wrote:
| Quote: | Hi Bill, indeed they are balance weights and depending upon the static
John 40315
VH-XIO 50hrs
Thanks for the tip about the lockwire... will have to take a look.
Bill
