leading edge
larkrv10(at)yahoo.ca
PostPosted: Mon Apr 25, 2011 8:13 am    Post subject: leading edge Reply with quote
Hi all
I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing?
Since I'm only installing a single Duckworks HID landing light, is there any reason it has to go in the left, as opposed to the right? Convention seems to dictate the stall switch and pitot tube all go in the left as well. Is there a good reason for using the left? Opinions welcome.
Thx.
Rick
Southampton, Ont
#40956
pietflyr(at)bellsouth.net
PostPosted: Mon Apr 25, 2011 8:52 am    Post subject: leading edge Reply with quote
The only reason I could think of would be for shorter runs to the left side of the instrument panel, but there’s not much difference if you use the right side. Of course, if you put the landing light in the right side, its weight could help balance the weight of all that stuff in the left side.
Jack Phillips
#40610 Wings
Raleigh, NC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Sent: Monday, April 25, 2011 12:11 PM
To: RV10-list
Subject: leading edge
Hi all
Thx.
Rick
Southampton, Ont
#40956
tsts4
PostPosted: Mon Apr 25, 2011 9:44 am    Post subject: Re: leading edge Reply with quote
You could move all the stuff you mentioned to the right side, but I'd still put the landing light on the left because that 's the side you'll be on (most likely) and the light's coverage will be more to that side of the plane. The mounting kit isn't really designed for left-right adjustment so you'd have to tinker to get the light aimed just right if you put it on the right side and wanted to optimize the lighting target area for the left seat. Not a show stopper by any stretch, but also not really something worth wasting time on IMO. Every mod, no matter how simple seems to add a lot of extra time to the build. Unless you have a good reason to relocate things from one side to the other, I recommend following the plans and build on. YMMV....
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
jump2(at)sbcglobal.net
PostPosted: Mon Apr 25, 2011 10:52 am    Post subject: leading edge Reply with quote
If you only put one light in, you want it on the left side, the pilot side. If you put it on Rt side when taxing you do not get full vision. Rt side landing, left side taxi.
Just my two cents.
Patrick Thyssen
N15PT
--- On Mon, 4/25/11, Jack Phillips <pietflyr(at)bellsouth.net> wrote:
Subject: RE: RV10-List: leading edge
Date: Monday, April 25, 2011, 11:48 AM
Jack Phillips
#40610 Wings
Raleigh, NC
To: RV10-list
Hi all
Thx.
Rick
Southampton, Ont
#40956
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com
AV8ORJWC
PostPosted: Mon Apr 25, 2011 10:59 am    Post subject: leading edge Reply with quote
I like the thought process. Why on the Left? The balance of CG from Left of Center to Over Center coupled with the reflection of light off of objects at a distance is easy with the old "Angle of Reflection Rule". Having twice as many Landing lights is fine, but I like the pursuit of CG as a reason for going to the Right. Our entire fleet has Pulse-Lights and both Landing/Flare circuits.
Then there are those on the list that know I am no fan of the left and always right leaning.
John
#40600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jack Phillips
Sent: Monday, April 25, 2011 9:49 AM
Subject: RE: leading edge
Jack Phillips
#40610 Wings
Raleigh, NC
To: RV10-list
Hi all
Thx.
Rick
Southampton, Ont
#40956
http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
5
PostPosted: Mon Apr 25, 2011 11:43 am    Post subject: leading edge Reply with quote
Just to let everyone know, I am going to pulse the wing tip lights, and intended to use them for taxi/landing if need be.  I kind of figured having the landing light as close as possible to being in-line with the PIC would be the proper way to go.
None the less, I will ensure I'm able to add another HID to the right wing in the future if need be.
Hmmm, maybe I'll move the pitot tube to the right side....
Thx guys,  Rick
Received: Monday, April 25, 2011, 6:57 PM
John
#40600
Jack Phillips
#40610 Wings
Raleigh, NC
To: RV10-list
Hi all
LarryRosen
PostPosted: Mon Apr 25, 2011 4:51 pm    Post subject: leading edge Reply with quote
My roll servo and aileron trim is in the right wing.  They are by far heaver than the pitot tube and stall warning that are in the left wing.  Also there are 7 wires to the servo and 5 (i thing) to the trim, filling up the conduit.
Larry
On 4/25/2011 3:40 PM, Rick Lark wrote: [quote] Just to let everyone know, I am going to pulse the wing tip lights, and intended to use them for taxi/landing if need be.  I kind of figured having the landing light as close as possible to being in-line with the PIC would be the proper way to go.
Thx guys,  Rick
--- On Mon, 4/25/11, John Cox <johnwcox(at)pacificnw.com> (johnwcox(at)pacificnw.com) wrote:
From: John Cox <johnwcox(at)pacificnw.com> (johnwcox(at)pacificnw.com)
John
#40600
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jack Phillips
Jack Phillips
#40610 Wings
Raleigh, NC
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rick Lark
To: RV10-list
Hi all
Thx.
Rick
Southampton, Ont
#40956
5
6
7 [b]
Larry Rosen
#40356
N205EN (reserved)
<http>
Tim Olson
PostPosted: Mon Apr 25, 2011 5:41 pm    Post subject: leading edge Reply with quote
Personally, I really like the dual HID's so much that my advice
is to cut the hole in each wing for the kit...and if you only
want one side for now, just do one side. But some day you'll
probably want one in the other side, and cutting the wing won't
appeal to you later.
Tim Olson - RV-10 N104CD
Thx guys, Rick
John
#40600
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jack
Phillips
*Sent:* Monday, April 25, 2011 9:49 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: leading edge
Jack Phillips
#40610 Wings
Raleigh, NC
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick Lark
*Sent:* Monday, April 25, 2011 12:11 PM
*To:* RV10-list
*Subject:* leading edge
Hi all
Opinions welcome.
Thx.
Rick
Southampton, Ont
#40956
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
Bob Turner
PostPosted: Mon Apr 25, 2011 6:06 pm    Post subject: Re: leading edge Reply with quote
I have the pitot on the right, because when I started I had this vision of the simple Van's pitot on the left, a heated pitot on the right. Well, that vision went away, and now there's an OAT probe in the hole where Van's pitot would have gone.
Bob Turner
RV-10 QB
PostPosted: Mon Apr 25, 2011 6:27 pm    Post subject: leading edge Reply with quote
Larry, after I wrote the reply below, I started thinking exactly as you have, and realized my -10 will have the servo and trim just like yours, so I guess I will leave "well enough alone".
Thx guys.........
Rick
--- On Tue, 4/26/11, Larry Rosen <N205EN(at)gmail.com> wrote:
Subject: Re: leading edge
Received: Tuesday, April 26, 2011, 12:47 AM
Larry
Thx guys,  Rick
John
#40600
Jack Phillips
#40610 Wings
Raleigh, NC
To: RV10-list
Hi all
