Firewall Oil cooler location
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
recapen(at)earthlink.net
PostPosted: Tue May 09, 2006 3:53 am    Post subject: Firewall Oil cooler location Reply with quote
Fellow builders,
I would like to use Vans stock location for my firewall mounted oil cooler - in order that I can use their prefabbed lines. I'm gonna need to build a couple regardless but they will be -6 instead of the oil cooler -8 lines.
I have Vans firewall foreward documentation but don't recall seeing a location called out. I'm using an Aerosport built O360 so the stock engine locations are available.
Anyone out there used Vans oil cooler hoses with their called out location? Please give me a leader on their documentation.
Ralph Capen
RV6A QB N822AR (at) N06 working on firewall foreward
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
k9hxt(at)sbcglobal.net
PostPosted: Thu May 11, 2006 8:00 pm    Post subject: Firewall Oil cooler location Reply with quote
Be sure to use 1/2" oil lines not 3/8".  You need all the flow you can get for cooling.
I mounted mine on the back of the left baffle so can't help on FW mount. I would just pick a place on the right side that will be clear of other stuff. My engine is a Aero Sport Power O-360 and I love it. Flying since July 2001. If I did a FW mount I would use a 9 tube cooler too. Again, hot oil temps are common on tri gears.
Larry
"Ralph E. Capen" <recapen(at)earthlink.net> wrote:
[quote]--> RV6-List message posted by: "Ralph E. Capen"
Fellow builders,
I have
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
