Vic Peters
Joined: 30 Oct 2009 Posts: 54 Location: Millinocket, Maine
Posted: Wed Jul 06, 2011 4:21 am Post subject: Too ht and sexy for my doors |
Hi all
Anything I should be mindful of when removing one or both doors for cooler flight in my Xtra?
_________________ Vic
912ul Xtra
Maine
Too old to cut the mustard but not the cheese. |
Mike Welch
Posted: Wed Jul 06, 2011 5:00 am Post subject: Too ht and sexy for my doors |
Vic,
That your seat belts are nice and tight..
| Quote: | Hi all
Vic
Thom Riddle
Posted: Wed Jul 06, 2011 5:26 am Post subject: Too ht and sexy for my doors |
Vic,
Just a guess but I suspect if flying with one door removed you will experience some yaw effects, could be more than you want. My Kolb only has a flip-over canopy so I can't say for certain.
Thom Riddle
Slingshot
On Wed, Jul 6, 2011 at 8:21 AM, Vic Peters <vicsv(at)myfairpoint.net (vicsv(at)myfairpoint.net)> wrote:
[quote] --> Kolb-List message posted by: "Vic Peters" <vicsv(at)myfairpoint.net (vicsv(at)myfairpoint.net)>
Hi all
Vic
912ul Xtra
Maine
http://forums.matronics.com/viewtopic.php?p=345092#345092
le, List Admin.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Wed Jul 06, 2011 5:36 am Post subject: Re: Too ht and sexy for my doors |
My ASI is way off when I remove my doors. I would suggest you go up to a safe height and verify your indicated stall speed.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
Vic Peters
Posted: Wed Jul 06, 2011 6:04 am Post subject: Re: Too ht and sexy for my doors |
Scott
Do you have a static line connected also?
912ul Xtra
Maine
olendorf
Posted: Wed Jul 06, 2011 12:43 pm Post subject: Re: Too ht and sexy for my doors |
I have a static port in a tube right under the pitot tube but this gave a reading that was too high or too low, I can't remember. So I added a T connector which splits the static between inside the nosecone and the static tube. That is usually right on the money until I take my doors off.
Schenectady, NY
by0ung(at)q.com Guest
Posted: Wed Jul 06, 2011 6:29 pm Post subject: Too ht and sexy for my doors |
if you can figure if the inside is higher or lower pressure than the static
probe....
if the static pressure is too high, you can put a small wahser just before
the static hole and decrease the static pressure.
if the static pressure is too low, you can put a small washer just behind
the static hole and increase the pressure,
moving the washer further forward or further back from the static opening,
will reduce the effect.,,,, or a smaller washer will reduce the effect.
boyd young
mkiii utah
