raimo.toivio(at)rwm.fi Guest
Posted: Wed Jul 06, 2011 1:39 pm Post subject: Tire /tyre landing incident /accident |
Tim,
what is your tube brand name?
Tyre /tube sizes? 7.00-6?
Raimo
-----Alkuperäinen viesti-----
Sent: Wednesday, July 06, 2011 11:12 PM
Subject: Re: Tire /tyre landing
incident /accident
<ward.t(at)xtra.co.nz>
I keep the tyre pressure between 28-30 psi. No
problems with the tyre after 250hours 464 cycles.
Only disadvantage with the higher pressure is one
has to be more diligent on controlling the
aircraft path when landing on hard pavement
runways. I did not use the original Europa tyre
but use the Mccready? Air tire, narrower and
stronger.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch,
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 7/07/2011, at 6:19 AM, Jerry Rehn
<rehn(at)rockisland.com> wrote:
10 years, one slow leak, 18 lbs
Mono
Jerry
On Jul 6, 2011, at 10:36 AM,
> All monowheel drivers
> Following this thread today... I have a few
> commits to throw to the forum...I notice that
> Europa requires very low tire pressure in
> their manual....
> I also noticed today that quiet a few monowheel
> drivers are having flat's....I suspect that
> with the low air pressure, when you land the
> sidewals are flexing due to low air
> pressure...this is probably "pinching the inner
> tube" and then the tire goes flat....
> I have always kept 32 PSI in the tire. IN 10
> years, and two tires and tubes, I have never
> had a flat....Yes I know I have been blessed by
> the good luck god..
> Thank about it with 32 P S In the tube the
> sidewalls are not flexing......Just my
> thought's on this matter....
> Jim Brown
> Monowheel.......
> ---- Paul McAllister
> <paul.the.aviator(at)gmail.com> wrote:
>> Hi All,
>> I have found that the inner tubes on my mono
>> to be an ongoing problem and I
>> now routinely change my inner tube every 150
>> hours as preventative
>> maintenance. The tubes I have been using are
>> not very expensive and I think
>> that they are from China. Recently Bud made me
>> aware that there is a
>> certified inner tube available at about 3
>> times the cost and if they last
>> longer then they would be so worth it!
>> I do recall when I mentioned on the forum that
>> I was losing inner tubes
>> regularly that some people were surprised and
>> that they had not had a
>> problem so perhaps this can be accounted for
>> by different inner tubes being
>> available. The failure I get is that the side
>> wall of the inner tube get
>> small splits in it due to chafing. I
>> typically run my tire at about 24 psi,
>> which is higher than the recommended by
>> Europa. BTW I do use talcum powder
>> when I install the inner tube.
>> I have had 3 blow outs on a hard surface and
>> fortunately I was able to keep
>> directional control. The challenge I found is
>> that with a flat tire the
>> mono is nearly impossible to move. It happen
>> to me at a large airport once
>> which got the airport authority excited
>> because they had to shut the runway
>> down and divert all of the 737's to a shorter
>> runway. I now carry a jacking
>> block, tools and a spare inner tube with me
>> and I can now do the change out
>> in less than 30 minutes.
>> Next time around I am going to try a certified
>> inner tube in the hope that
>> it will last longer.
>> Paul
>>> *From:* Raimo Toivio <raimo.toivio(at)rwm.fi>
>>> *Sent:* Wednesday, July 06, 2011 3:21 AM
>>> *To:* Raimo Toivio <raimo.toivio(at)rwm.fi>
>>> *Subject:* Tire /tyre landing incident
>>> /accident
>>> Dear All,
>>> it is a long time since I have been here.
>>> Today it happened something and I
>>> got an Europa Energy Burst (aka ENB) to write
>>> on the list. I think this
>>> could be useful info for most of you Europa
>>> (or any GA plane) operators. Let
>>> me tell you what was it and how it went:
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
ward.t(at)xtra.co.nz Guest
Posted: Wed Jul 06, 2011 3:59 pm Post subject: Tire /tyre landing incident /accident |
Raimo,
Not sure what the size was. Next time I go out to the aircraft I will have a look. It was a McCreary from:
www.aircraftspruce.com/menus/lg/tirestubes_mccreary.html
Cheers,,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch,
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 7/07/2011, at 9:36 AM, "Raimo Toivio" <raimo.toivio(at)rwm.fi> wrote:
Tim,
Raimo
-----Alkuperäinen viesti----- From: Tim Ward
Subject: Re: Tire /tyre landing incident /accident
I keep the tyre pressure between 28-30 psi. No problems with the tyre after 250hours 464 cycles. Only disadvantage with the higher pressure is one has to be more diligent on controlling the aircraft path when landing on hard pavement runways. I did not use the original Europa tyre but use the Mccready? Air tire, narrower and stronger.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch,
New Zealand.
Ph 64 3 3515166
Mob 0210640221
> Mono
> Jerry
> Sent from my iPhone
>> Following this thread today... I have a few commits to throw to the forum...I notice that Europa requires very low tire pressure in their manual....
>> I also noticed today that quiet a few monowheel drivers are having flat's....I suspect that with the low air pressure, when you land the sidewals are flexing due to low air pressure...this is probably "pinching the inner tube" and then the tire goes flat....
>> I have always kept 32 PSI in the tire. IN 10 years, and two tires and tubes, I have never had a flat....Yes I know I have been blessed by the good luck god..
>> Thank about it with 32 P S In the tube the sidewalls are not flexing......Just my thought's on this matter....
>> Jim Brown
>> Monowheel.......
>> ---- Paul McAllister <paul.the.aviator(at)gmail.com> wrote:
>>> Hi All,
>>> I have found that the inner tubes on my mono to be an ongoing problem and I
>>> now routinely change my inner tube every 150 hours as preventative
>>> maintenance. The tubes I have been using are not very expensive and I think
>>> that they are from China. Recently Bud made me aware that there is a
>>> certified inner tube available at about 3 times the cost and if they last
>>> I do recall when I mentioned on the forum that I was losing inner tubes
>>> regularly that some people were surprised and that they had not had a
>>> problem so perhaps this can be accounted for by different inner tubes being
>>> available. The failure I get is that the side wall of the inner tube get
>>> small splits in it due to chafing. I typically run my tire at about 24 psi,
>>> which is higher than the recommended by Europa. BTW I do use talcum powder
>>> I have had 3 blow outs on a hard surface and fortunately I was able to keep
>>> directional control. The challenge I found is that with a flat tire the
>>> mono is nearly impossible to move. It happen to me at a large airport once
>>> which got the airport authority excited because they had to shut the runway
>>> down and divert all of the 737's to a shorter runway. I now carry a jacking
>>> block, tools and a spare inner tube with me and I can now do the change out
>>> Next time around I am going to try a certified inner tube in the hope that
>>> Paul
>>>> *Subject:* Tire /tyre landing incident /accident
>>>> Dear All,
>>>> it is a long time since I have been here. Today it happened something and I
>>>> got an Europa Energy Burst (aka ENB) to write on the list. I think this
>>>> could be useful info for most of you Europa (or any GA plane) operators. Let
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Posted: Wed Jul 06, 2011 4:16 pm Post subject: Tire /tyre landing incident /accident |
Graham,
Yes, I think that is why Kim Prout recommended the narrower McCreary tire and higher pressure
when I flew with him many years ago now.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch,
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 7/07/2011, at 11:58 AM, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]Tim
my dilute memory tells me that some of us concluded that the low pressure recommended allowed the tire to slip circumferentialy too much which steadily wore out the inner tube. I used a higher pressure for that reason.
Graham
From: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
Sent: Wednesday, 6 July, 2011 21:38:46
Subject: Fwd: Tire /tyre landing incident /accident
| Quote: | --> Europa-List message posted by: Tim Ward <[url=mailto:ward.t(at)xtra.co.nz]ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)[/url]>
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch,
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 7/07/2011, at 6:19 AM, Jerry Rehn <[url=mailto:rehn(at)rockisland.com]rehn(at)rockisland.com (rehn(at)rockisland.com)[/url]> wrote:
| Quote: | --> Europa-List message posted by: Jerry Rehn <[url=mailto:rehn(at)rockisland.com]rehn(at)rockisland.com (rehn(at)rockisland.com)[/url]>
Mono
Jerry
On Jul 6, 2011, at 10:36 AM, <[url=mailto:acrojim(at)cfl.rr.com]acrojim(at)cfl.rr.com (acrojim(at)cfl.rr.com)[/url]> wrote:
| Quote: | --> Europa-List message posted by: <[url=mailto:acrojim(at)cfl.rr.com]acrojim(at)cfl.rr.com (acrojim(at)cfl.rr.com)[/url]>
| Quote: | All monowheel drivers
| Quote: | Following this thread today... I have a few commits to throw to the forum...I notice that Europa requires very low tire pressure in their manual....
| Quote: | I also noticed today that quiet a few monowheel drivers are having flat's....I suspect that with the low air pressure, when you land the sidewals are flexing due to low air pressure...this is probably "pinching the inner tube" and then the tire goes flat....
| Quote: | I have always kept 32 PSI in the tire. IN 10 years, and two tires and tubes, I have never had a flat....Yes I know I have been blessed by the good luck god..
| Quote: | Thank about it with 32 P S In the tube the sidewalls are not flexing......Just my thought's on this matter....
| Quote: | ---- Paul McAllister <[url=mailto:paul.the.aviator(at)gmail.com]paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)[/url]> wrote:
| Quote: | | Quote: | I have found that the inner tubes on my mono to be an ongoing problem and I
| Quote: | | Quote: | now routinely change my inner tube every 150 hours as preventative
| Quote: | | Quote: | maintenance. The tubes I have been using are not very expensive and I think
| Quote: | | Quote: | that they are from China. Recently Bud made me aware that there is a
| Quote: | | Quote: | certified inner tube available at about 3 times the cost and if they last
| Quote: | | Quote: | longer then they would be so worth it!
| Quote: | | Quote: | I do recall when I mentioned on the forum that I was losing inner tubes
| Quote: | | Quote: | regularly that some people were surprised and that they had not had a
| Quote: | | Quote: | problem so perhaps this can be accounted for by different inner tubes being
| Quote: | | Quote: | available. The failure I get is that the side wall of the inner tube get
| Quote: | | Quote: | small splits in it due to chafing. I typically run my tire at about 24 psi,
| Quote: | | Quote: | which is higher than the recommended by Europa. BTW I do use talcum powder
| Quote: | | Quote: | when I install the inner tube.
| Quote: | | Quote: | I have had 3 blow outs on a hard surface and fortunately I was able to keep
| Quote: | | Quote: | directional control. The challenge I found is that with a flat tire the
| Quote: | | Quote: | mono is nearly impossible to move. It happen to me at a large airport once
| Quote: | | Quote: | which got the airport authority excited because they had to shut the runway
| Quote: | | Quote: | down and divert all of the 737's to a shorter runway. I now carry a jacking
| Quote: | | Quote: | block, tools and a spare inner tube with me and I can now do the change out
| Quote: | | Quote: | in less than 30 minutes.
| Quote: | | Quote: | Next time around I am going to try a certified inner tube in the hope that
| Quote: | | Quote: | it will last longer.
| Quote: | | Quote: | | Quote: | *From:* Raimo Toivio <[url=mailto:raimo.toivio(at)rwm.fi]raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)[/url]>
| Quote: | | Quote: | | Quote: | *Sent:* Wednesday, July 06, 2011 3:21 AM
| Quote: | | Quote: | | Quote: | *To:* Raimo Toivio <[url=mailto:raimo.toivio(at)rwm.fi]raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)[/url]>
| Quote: | | Quote: | | Quote: | *Subject:* Tire /tyre landing incident /accident
| Quote: | | Quote: | | Quote: | it is a long time since I have been here. Today it happened something and I
| Quote: | | Quote: | | Quote: | got an Europa Energy Burst (aka ENB) to write on the list. I think this
| Quote: | | Quote: | | Quote: | could be useful info for most of you Europa (or any GA plane) operators. Let
| Quote: | | Quote: | | Quote: | me tell you what was it and how it went:
= Archive Search & Download, 7-Day Browse, Chat, FAQ,
a-List">http://ww==========================; - MATRONI; [/url][url=http://forums.matronics==========================;%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0-%20List%20Contribution%20Web%20Sitnbsp;%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0%C2%A0-Matt%20Dralle,%20List%20Admin.%3C/span%3E%3Cbr%3E%3Csp]http://www.matronics.com=======================
| [/url]
[url=http://www.matronics.com/Navigator?Europa-List]
acrojim7534(at)YAHOO.COM Guest
Posted: Thu Jul 07, 2011 1:36 pm Post subject: Tire /tyre landing incident /accident |
Raimo, I will be at the airport tomorrow, and will get the information for you.
Jim
Sent: Wednesday, July 6, 2011 5:34 PM
--> Europa-List message posted by: "Raimo Toivio" <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)>
Dear Jim
Read careful my post: I like to use pressure 2,0 - 2,2 bars. 2,1 bar = 30,45 PSI. So we land with same pressures. Pressure - low or high - is not a reason.
What is your tube brand name?
What is your tube and tyre size?
Until I will get a reason and solution I am going to do same as Paul is doing: changeing regularly tube. Makes me sense to change it every year (= in my case every 50 hrs /about 50 - 100 landings. I never can do it in 30 minutes but so what. Tube is very cheap. For example yeasterday I spent 6 hrs fighting with that problem with my wife and that newspaperman. That is 18 hrs + all the extra fees + 400 km driving car. That must be same as buying let us say 100 pcs of tubes.
BTW also I use masses of baby bottom talcum. That delicate scent is a bit embarrassing...
Raimo
-----Alkuperäinen viesti----- From: acrojim(at)cfl.rr.com (acrojim(at)cfl.rr.com)
Sent: Wednesday, July 06, 2011 8:36 PM
--> Europa-List message posted by: <acrojim(at)cfl.rr.com (acrojim(at)cfl.rr.com)>
Jim Brown
Monowheel.......
---- Paul McAllister <paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)> wrote:
| Quote: | Hi All,
Paul
> *From:* Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)>
> *To:* Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)>
> *Subject:* Tire /tyre landing incident > /accident
> Dear All,
> it is a long time since I have been here. > Today it happened something and I
> got an Europa Energy Burst (aka ENB) to write > on the list. I think this
> could be useful info for most of you Europa > (or any GA plane) operators. Let
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
http:nbsp; =======================
Posted: Thu Jul 07, 2011 2:02 pm Post subject: Tire /tyre landing incident /accident |
Jim, thanks (do not bother to check tube brand name by removing the tire!!!)!
Raimo
Sent: Friday, July 08, 2011 12:32 AM
Jim
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
budyerly(at)msn.com Guest
Posted: Sat Jul 09, 2011 7:45 am Post subject: Tire /tyre landing incident /accident |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> To all, and congrats to Raimo Toivio
When preparation, proficiency and proper procedures meet a potentially catastrophic chain of events, the chain is broken and the aircraft, pilot and passengers all have a story to tell rather than being an accident statistic.
Your thorough planning for tire changes in the field, spares, and most importantly a lovely and supportive wife makes the event a nuisance tire change out in the field, so I am hoping you bought your wife a great dinner and told her how much you appreciate her.
As for tires and tubes, from what I can report from the US mono pilots that have shared their experiences with me here goes:
Original Classic Equipment was an industrial 8 inch tire and tube. Cheap, strong but rather thin with squishy sides. The clearances were minimal from the frame and cockpit module and during landing the brake caliper on a flat tire tore it up pretty quick. About 2000 most guys started going with the 7 inch McCreary as a replacement around here. It is narrower and of course a little lower. The original tube was a bit thin but cheap at $35 for a lawn tire tube.
Replacement Tires:
The McCreary 7 inch six ply seems to work very well with very long life. This tire has more clearance from the frame, the wheel well, and its six ply sides is very stiff. It is available through Europa or Aircraft Spruce (PN 06-09600):
for about $130 US and is worth every penny.
Replacement Tubes: Europa tubes are now made by McCreary and are for a 7-8 inch tire. They are very well built, and have the exact 90 degree bend and placement of the valve stem for the mono's wheel. They are about $130 each, and again worth every penny. It is my experience they are changed only on puncture not wear.
Most taxi failures need a serious autopsy of the tube. I have found with new clients that they pinch the tube or cut the stem. Once the tire goes flat, it gets cut by the brake caliper. We have gone to a full proof method here in the shop. First we inspect the wheel for any burrs or sharp edges on the rim and especially on the valve stem. We smooth these out if present. Then thoroughly clean and dry the wheel. We cut card stock that fits the recess machined into the wheel and glue it in place with super glue dabs on one side only. Then show the client how the wheels go together and to watch for the white paper in the wheel half split with an inspection mirror to make sure all goes together easily. Then the tube is lightly powdered , inserted into the tire, aligned with the stem aligned with the dot (not always present) and slide the wheel into the tire. Carefully align the tube stem and ensure the tube is not twisted. Now carefully install the other wheel half and gently push the two halves together. Insert bolts and pull up evenly. The tire is ready to inflate.
A suitable lubricant for tire to wheel during installation is not axel grease according to the FAA maintenance folks. There is no reason for lube on a well maintained rim free of dirt, corrosion etc. If the tire will not go on the rim, use a proper lube such as Freylube or a mixture of dish soap and water with no more than 10% mineral oil. Allow the solution to dry before putting the tire in use. Petroleum lubricants between the tire and rim may cause the tire to rotate on hard braking or run-up (and the tire will rotate on the rim with a 914 at full blast with an Airmaster Prop), causing tube stem or tube failure. Learn from my mistake. Read Michelin's guide to tire installation: http://www.airmichelin.com/uploadedFiles/MichelinAirDev/StandardContent/Resource/certification_level_2.pdf
Great job Raimo,
Regards to all,
Bud Yerly
Europa Tech Support
Custom Flight Creations, Inc.
www.customflightcreations.com
(813) 653-4989
58.84 KB |
10242 Time(s) |
![Europa%20A2A-ala2OK[1].png](files/Europa_20A2A-ala2OK_1__124.png)
Posted: Sun Jul 10, 2011 2:27 pm Post subject: Tire /tyre landing incident /accident |
Hi! All
Just for information and safety knowledge I can declare that my trike has
landed with a flat nose wheel without anything startling . I had been aware
of the likelihood prior to landing .
To all
Bob Harrison G-PTAG
Posted: Mon Jul 11, 2011 9:54 am Post subject: Tire /tyre landing incident /accident |
Raimo; sorry for the delay... The tire is a Goodyear 700X6 6Ply rated. This tire has about 400 hours on it. The tread wear is showing about half the tread is gone...
JimBrown
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Posted: Mon Jul 11, 2011 2:50 pm Post subject: Tire /tyre landing incident /accident |
Jim
that can only be a confirmation that the pilot is as good as the tyre!
Graham
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Monday, 11 July, 2011 18:49:39
JimBrown
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
[quote]http://www.matro====================
Posted: Tue Jul 12, 2011 2:50 am Post subject: Tire /tyre landing incident /accident |
Thanks Graham, I just thought I was "lucky". When you are flying a "one wheeled taildragger" you are always one landing from disaster !!!!!!!!!!!!!!!!
Jim
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Sent: Monday, July 11, 2011 6:47 PM
Jim
Graham
JimBrown
Dear Jim
Raimo
I also noticed today that quiet a few monowheel drivers are having flat's...I suspect that with the low air pressure, when you land the sidewals are flexing due to low air pressure...this is probably "pinching the inner tube" and then the tire goes flat....
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
el=nofollow target=_blank>http://www.matronics.com/Navigator?Europa-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
Posted: Tue Jul 12, 2011 5:42 am Post subject: Tire /tyre landing incident /accident |
Hi Jim,
have you any idea what is your tube brand name? I think that (the tube) could be something between happy landing and a possible disaster or pain at least.
To prevent future tube-related accidents my plan is to go as follows:
1) change a very best available tube (www.desser.com , McCreary ?)
2) change it for new one regularly ie. once a year to prevent it is ageing.
3) consider seriously what is the best size for it (must be same as tyre and that is in my case 7.00-6)
4) install it with extreme care and baby bottom talcum
5) keep a good tyre pressure ie. 2,0 – 2,2 bar
6) fill the tyre with some well known pre puncture liquid (www.slime.com ?)
7) have a low tube pressure on-flight control system (www.conrad.fr ,thanks Alain)
carry always in a plane a spare tube (with a lifting block)
Raimo Toivio OH-XRT Finland
Sent: Monday, July 11, 2011 8:49 PM
JimBrown
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Posted: Tue Jul 12, 2011 8:14 am Post subject: Tire /tyre landing incident /accident |
I purchased the tube whenI purchased the tire from Dresser.....Sorry I do not know the name of the tube...Your outlined plan seems to be well thought out.
Jim
Sent: Tuesday, July 12, 2011 9:37 AM
Hi Jim,
JimBrown
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
h&jeuropa
Posted: Fri Jul 15, 2011 6:33 am Post subject: Re: Tire /tyre landing incident /accident |
We joined the flat tire mono club this past Tuesday, only we think ours had a different cause, not rubbing of the tube in the tire.
We have been doing a lot of training on a hard surface runway. The tire and tube had in excess of 500 landings on it. We thought before Heather flew on Tuesday that the tire looked a little low and thought the same before Jim flew after Heather (she did 7 T/O and ldgs). On Jim's 7th landing, the plane slowed quickly and there was a smell of rubber.
When we took the wheel/tire apart we found that the tube was perfect except the valve stem was pulled off. No holes or rub marks on the tube. Tire was damaged with a couple of broken cords and a cut on the outside from the wheel.
Our conclusion is that the tire was low (we normally run 18 psi) and over the course of 14 T/O and ldgs with some swerving on the runway, the tire pulled from the bead of the wheel and rotated causing the valve stem to be pulled off.
The damaged tire was a US Speciality Tire AIR TRAC size 7.00 x 6 6 ply rating and the tube was a Cheng Sing (we think we got the tube from Europa UK).
We were able to get a Goodyear Flight Custom II tire locally and fitted our spare tube that is Chinese and purchased from Wicks Aircraft supply, Part Number TB-MTAT8X6 (tubes with the 90 deg valve stem are not listed on Dresser Tire or ACS websites). The only marking on the tube is "Quality Assured" and some Chinese characters! The new tire seems to have a flatter tread and doesn't bulge as much. Landings yesterday with it on pavement were no different than previously.
We always use a lot of talcum when fitting a tube. We inflate a new tube outside the tire first to get out wrinkles. Then we deflate it, talcum it (talcum the tire too), insert into the tire and inflate. Then deflate again, and fit the wheel (usually twice since we forget the spacer!!). Inflate again and deflate again. Finally inflate the final time to 18 psi. Be sure the valve stem is aligned with the red dot on the tire for balance.
When we got our Europa wheel, we found the opening for the valve stem was quite rough. We filed and sanded it to make it as large and smooth as possible. We used Scotchbrite to clean the wheel before fitting the new tire and tube. There was a lot of rubber debris on the bead and even inside the wheel.
Jim & Heather
Rocketman
Posted: Fri Jul 15, 2011 7:41 am Post subject: Tire /tyre landing incident /accident |
First, I fly a tri-gear, so take this with a grain of salt. In racing,
it is common to "screw" the tire to the rim, using short pointed sheet
metal screw. Would this not be workable in the nomowheel to prevent the
tire slipping on the wheel?
Jeff - Baby Blue
On 7/15/2011 9:33 AM, h&jeuropa wrote:
Jim& Heather
http://forums.matronics.com/viewtopic.php?p=346502#346502
Checked by AVG - www.avg.com
peterz(at)zutrasoft.com Guest
Posted: Fri Jul 15, 2011 8:09 am Post subject: Tire /tyre landing incident /accident |
...and in dirtbike/motocycling, the low-pressure tire is clamped to the inside of the rim (a "rimlock") and tightened with a with a simple bolt. as per: http://www.motorcycle-superstore.com/2/9/203/4355/ITEM/Motion-Pro-Alloy-Rim-Lock.aspx
Pity there nothing similar for the low pressure Europa wheel.
Pete
A239
On Fri, Jul 15, 2011 at 11:38 AM, Jeff B <topglock(at)cox.net (topglock(at)cox.net)> wrote:
[quote]--> Europa-List message posted by: Jeff B <topglock(at)cox.net (topglock(at)cox.net)>
First, I fly a tri-gear, so take this with a grain of salt. In racing, it is common to "screw" the tire to the rim, using short pointed sheet metal screw. Would this not be workable in the nomowheel to prevent the tire slipping on the wheel?
Jeff - Baby Blue
| Quote: | --> Europa-List message posted by: "h&jeuropa"<butcher43(at)att.net (butcher43(at)att.net)>
Jim& Heather
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
kheindl(at)msn.com Guest
Posted: Fri Jul 15, 2011 9:26 am Post subject: Tire /tyre landing incident /accident |
I remember once listening to a presentation by a professional engineer and pilot at an EAA meeting.He pointed out that it is very important to make a permanent mark on the rim(s) and on the tire after tube installation. And this should be checked as part of every preflight inspection. Apparently this slippage is quite common, regardless of aircraft type, when landing on hard runways.
Karl
[quote] Subject: Re: Tire /tyre landing incident /accident
Date: Fri, 15 Jul 2011 07:33:58 -0700
--> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net>
Jim & Heather
Posted: Mon Jul 18, 2011 5:29 am Post subject: Tire /tyre landing incident /accident |
This has always been my habit (similar markings also to the oilfilter & base as well). Just do it simple by red permanent marker. I have never seen any movements between the rim and tire/tyre. So that is not the reason for once-a-year-flat-tyre-syndrom in my case.
Raimo OH-XRT Finland
Sent: Friday, July 15, 2011 8:21 PM
Subject: RE: Re: Tire /tyre landing incident /accident
I remember once listening to a presentation by a professional engineer and pilot at an EAA meeting. He pointed out that it is very important to make a permanent mark on the rim(s) and on the tire after tube installation. And this should be checked as part of every preflight inspection. Apparently this slippage is quite common, regardless of aircraft type, when landing on hard runways.
Karl
| Quote: | From: butcher43(at)att.net
Jim & Heather
| Quote: | [b]
[/b] [quote][b]
paul.the.aviator(at)gmail Guest
Posted: Mon Jul 18, 2011 9:11 am Post subject: Tire /tyre landing incident /accident |
Hi All,
Jim's comments prompted my to share some additional thoughts. I found that my new tyre "stood taller" than the one I replaced. My theory is that the old tyre was run at low pressures so long that the side walls lost their strength. I think the design pressure for this tyre is something like 35 psi.
The other comment was that I did loose one inner tube to slippage, and two tubes to side wall wear so I increased my running pressure to around 22 ~ 24 psi. I used to have a maker on the side, but I forgot to put in on this time so thanks for the reminder.
I do have a question to the forum. is is possible to seal the split rim and turn it into a tube less configuration ?
Paul
Posted: Mon Jul 18, 2011 9:44 am Post subject: Tire /tyre landing incident /accident |
All,
I think the side wall wearing is the point and that will be high-lighted when a low pressure, not a quality tube, ageing, bad manners when installing and a wrong tube size.
Check this,
http://www.ehow.com/how_7865009_replace-aircraft-inner-tubes.html
this for a quality
http://www.airmichelin.com/uploadedFiles/MichelinAirDev/StandardContent/Product/MAIR_SS_AIRSTP.pdf
and this for nose-wheelers:
http://www.aircraftspruce.com/catalog/lgpages/tiresensor.php
Also, consider using Nitrogen instead of air. There are many obvious benefits.
Check
http://www.getnitrogen.org/why/index.php
From: Paul McAllister (paul.the.aviator(at)gmail.com)
Sent: Monday, July 18, 2011 7:41 PM
Subject: Re: Re: Tire /tyre landing incident /accident
Hi All,
Paul
Posted: Mon Jul 18, 2011 10:11 am Post subject: Tire /tyre landing incident /accident |
Jim and all
The problem is to find and get high quality tubes. There are many top-of-the-line tube brands like Michelin or Good Year but they do not have types with a valve stem bent to 90 degrees. They say tubes with 90 degree valves are only for light aircrafts and their owners do not pay for quality. They claim they buy only low prices and offers...
However, brand name Leakguard by Dresser promised to make size 7.00x6 with a valve stem 90 degrees as a special order.
We do not have Leakguard model because the 90 degree is for Light Sport Aircraft.
I can have special order these in Aircraft Grade, Leakguard with 100 pcs. minimum at $42.95 each on 100 pcs. order. Delivery 60 days.
Maybe you can get the owners together to buy 100?
Best regards
Steve
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Steven Chlavin stevenc(at)desser.com (stevenc(at)desser.com)
Desser Tire & Rubber Co., Inc.
6900 Acco Street
Montebello, CA. 90640 USA
Tel. 323-721-4900 x304 - 800-247-8473
Fax 323-721-7888
The Aircraft Tire Supermart
Los Angeles - Memphis
www.desser.com
View our catalog at http://www.desser.com/epdf/dtr_catalog.pdf
I could buy alone let us say 5 of them. How about you? How many of you are in?
Sent: Tuesday, July 12, 2011 7:11 PM
Jim
Hi Jim,
JimBrown
Subject: Re: Europa-List: Tire /tyre landing incident /accident
Dear Jim
Raimo
Jim Brown
Monowheel.......
| Quote: | Hi All,
Paul
> Dear All,
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
