Specification data for RV-12 required for certification.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List
godobcn(at)gmail.com
PostPosted: Thu Jul 14, 2011 4:53 am    Post subject: Specification data for RV-12 required for certification. Reply with quote
Hello,
In Spain, prior to start building, we are required to submit the plane
specifications to our Aviation Authorities.
I'm filling the form, but I'm missing part of the data required for the RV-12.
Does anyone have an idea on where to find the original plans data, or
where to turn to get these set of info, please?
The data requested not found neither on the POH, MM or the Web is:
WING:
Area:
Angle of incidence:
Length ailerons:
Max-Min angles of control ailerons:
Area Flaps:
HORIZONTAL STABILATOR:
Span:
Area:
Angle of incidence:
Maximum-Minimum angle deflection:
VERTICAL STABILATOR:
Hight:
Area:
Angle of incidence:
RUDDER:
Area:
LANDING GEAR TYPE:
Ground Clearance:
Distance between wheel centers:
Type of shock absorbing system:
Type of material
TRIM:
Type:
Position:
PROPELLER:
Diameter:
Material:
Step:
Any help will be really appreciated!
Godo Barrenechea
Barcelona (Spain)
- The Matronics RV12-List Email Forum -
http://www.matronics.com/Navigator?RV12-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV12-List All times are GMT - 8 Hours
