Firewall
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
rockford67
PostPosted: Thu Jul 21, 2011 8:13 am    Post subject: Firewall Reply with quote
Hey Builders,
Was there any specific instruction on installing a firewall in the pulsar xp? Mine seems to have an aluminum one, but I MUST have something proven to be fire rated. My inspector suggests that a lot of glass planes used fibrefax on the firewall which may suffice, and with the aluminum on top would be fine, however, I can't seem to find anything in the manuals and logs describing any specific application. What did most of you do?
The standard acceptable firewall here is Stainless steel. My plan is to add a stainless layer over top of the aluminum one as it appears to be bonded in and I'd prefer not to remove it. Of course, if there is fibrefax behind as part of the original fuse kit then I'm good too...
Any thoughts?
Chris
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
sonja.englert(at)juno.com
PostPosted: Thu Jul 21, 2011 9:18 am    Post subject: Firewall Reply with quote
I have a stainless steel firewall. It would make sense to remove the aluminum, it does nothing but add weight.
Sonja
Mortgage Rates at 2.37%
$250,000 loan for $650/month. See New Payment - No SSN Rqd. Save Now!
http://thirdpartyoffers.juno.com/TGL3131/4e285f2b989ac1256best06duc
pulsar331(at)sbcglobal.ne
PostPosted: Thu Jul 21, 2011 9:57 am    Post subject: Firewall Reply with quote
I used Fiberfax with aluminum over it. The aluminum not only slows down any fire damage but keeps the Fiberfax clean and in place.  It seemed to be a pretty popular way to go back when Pulsars were being built (sorry Tom) so yours may already have it installed behind the aluminum.
Bill
N331BP
Pulsar XP
Sent: Thu, July 21, 2011 12:13:16 PM
Subject: Firewall
--> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)>
Hey Builders,
Any thoughts?
Chris
http://forums.matronics.com/viewtopic.php?p=347314#347314
< -Matt Drall============
rockford67
PostPosted: Thu Jul 21, 2011 7:47 pm    Post subject: Re: Firewall Reply with quote
Sonja
Sonja,
I'm going to see what behind the aluminum first, and if its fibrefax leave it alone if that's okay with my inspector. If not, I'll probably pull it off as you suggest. I might shave a couple pounds off in the process.
C
esalehto(at)yahoo.com
PostPosted: Fri Jul 22, 2011 8:48 am    Post subject: Firewall Reply with quote
Hi Chris,
I have fibrefax and stainless steel top of that.
-Esa
Sent: Thursday, July 21, 2011 11:13 AM
Subject: Firewall
Hey Builders,
Any thoughts?
Chris
http://forums.matronics.com/viewtopic.php?p=347314#347314http://www.matronics.com/Navigator?Pulsar-Li>
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
