Pulsar-List:Firewall test
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
sonja.englert(at)juno.com
PostPosted: Fri Jul 22, 2011 6:48 am    Post subject: Pulsar-List:Firewall test Reply with quote
The only thing the aluminum is useful for is protection of the fiberfrax from liquids. The melting point of aluminum is way below the >2000 F expected from a fire. So if there is a fire, this will happen: hole is melted in the aluminum, fiberfrax does not protect anything, resin is burned out from composite sheet of fuselage, toxic smoke enters the cabin. I have watched a lot of firewall burn tests, they are nasty even if performed outside. Direct exposure to the smoke in the cockpit must be avoided. The only way is a sealed firewall.
A steel sheet protects from burn-through, fiberfrax provides some insulation to keep the temperature of the composite bulkead low enough to prevent it smoking, at least for a while.
Sonja
57 Year Old Mom Looks 27!
Mom Reveals $5 Wrinkle Trick That Has Angered Doctors!
http://thirdpartyoffers.juno.com/TGL3131/4e298d4c8bacd1558ccst01duc
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
rockford67
PostPosted: Fri Jul 22, 2011 9:17 am    Post subject: Re: Pulsar-List:Firewall test Reply with quote
Ya, that's what I'm hearing now. I wonder if there are any link on Youtube to see some of these tests? Would make a compelling argument for changing to SS at the next opportunity!
Thanks for your expertise!
C
PostPosted: Sat Jul 23, 2011 4:27 am    Post subject: Pulsar-List:Firewall test Reply with quote
The tests we did were for Cessna. We did take videos, but they are not posted for the public.
Sonja
http://thirdpartyoffers.juno.com/TGL3131/4e2abd8b37b3817ee9cst05duc
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
