John Brunke
Posted: Tue May 16, 2006 4:20 pm Post subject: Rivet removal |
Dear Listers,
I've been following this list for a long time and know I'll see some good replys.
I just started a -7 tail kit. Obviously drilling out rivets becomes part of the process.
There is a tool called a "multi-master" made by Fein. It is usually used in woodworking but I
tried using it as a rivet removal tool on a test piece that I put together. The multi-master is usually used
for sanding, but comes with cutting tools. The cutting tool can lie flat on a surface and make a cut to
material sticking up from that flat surface such as a shop head on a rivet. I was able to cut through the
shop head very easily and used a punch to remove the rest of the rivet. It was quick and I didn't have to
worry about enlarging the drilled hole. I don't think it would work well where the hole was dimpled, but
did well on a flat surface.
My question is to ask anyone to tell me what is wrong with using this procedure? I welcome any comments.
John Brunke
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
tadsargent(at)bellsouth.n Guest
Posted: Tue May 16, 2006 4:46 pm Post subject: Rivet removal |
What ever works for you is the process you should use.
Press on.
Tad
N130TS RV7A
95 hours
dhall(at)donka.net Guest
Posted: Tue May 16, 2006 6:34 pm Post subject: Rivet removal |
My brother-in-law (worked at Lockheed) showed me a trick that works pretty well most of the time for flush rivets. You drill down deep enough that you've probably drilled out most of the dimpled area, then you can stick a spare drill bit into the cavity and pop the top of the rivet off. Then it's easier to drill more accurately straight through the remaining shank without enlarging the hole too much.
I also recently bought some oops rivets but I haven't used them yet. There were a few spots on the tail where they would have been used...
Don
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of J. Brunke
Sent: Tuesday, May 16, 2006 8:26 PM
To: rv7-list(at)matronics.com
Subject: Rivet removal
Dear Listers,
John Brunke
