Mic
Joined: 22 Jul 2011 Posts: 12 Location: Ashland, Oregon
Posted: Sun Aug 21, 2011 8:34 pm Post subject: Kolb MIIIX vs. Classic |
I just watched the MK3X YouTube video posted 2 weeks ago by ultralight news.
http://www.youtube.com/watch?v=T6LjOighew8
Having not flown in either aircraft, my opinions are solely based on observation watching videos. My first impression of the wide, shark-like nose of the Xtra was that it provided a significant amount of additional airfoil and would impact ground effect and possibly in-flight pitch characteristics. A Kolb pilot also brought this to my attention recently as well.
So, I would appreciate hearing from those of you with experience flying both of these aircraft. How do the flight characteristics differ?
Thank you all for your input.
_________________ Mic
"It is far better to grasp the universe as it really is than to persist in delusion, however satisfying and reassuring."
— Carl Sagan
"Education is not filling a bucket, but lighting a fire."
— W.B. Yeats |
Richard Pike
Posted: Sun Aug 21, 2011 9:12 pm Post subject: Re: Kolb MIIIX vs. Classic |
Extra W/912 felt like a truck compared to my MKIII Classic W/582, mods, & vg's. Aside from that - just the same. <grin>
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Mon Aug 22, 2011 4:48 am Post subject: Kolb MIIIX vs. Classic |
I doubt the nose has a noticeable effect on landing. Not enough surface area.There is a difference at cruise though which is why they changed the wing incidence.
My hybrid MkIII has a longer nose too and a really broad windshield. I still intend
to lower my incidence too.... -eventually.
BB, always another project.
"Never impose on others what you would not choose for yourself." – Confucius
On Aug 22, 2011, at 12:34 AM, Mic wrote:
[quote]--> Kolb-List message posted by: "Mic" <miceire(at)gmail.com (miceire(at)gmail.com)>
Mic
— Carl Sagan
— W.B. Yeats
http://forums.matronics.com/viewtopic.php?p=350168#350168
- The Kolb-List Email Forum -
--> http://www.matronics.com/Navigator?Kolb-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
- List Contribution Web Site -
Thank you for your generous support!
--> http://www.matronics.com/contribution
rickofudall
Posted: Mon Aug 22, 2011 6:13 am Post subject: Kolb MIIIX vs. Classic |
Although I am still fighting the good fight trying to get Ken Holle's Mk IIIX to not behave like a lawn dart, which, I believe, is particular to this airplane only and not Mk IIIX's in general, I do have one data point. Some review first. The wing incidence on this aircraft has been set at 2.8 degrees relative to the engine mount, the low end of the factory recommended setting of 2.8 to 3.4 degrees. It has a full swivel tail wheel with a 4" diameter wheel and the tail wheel strut has been shortened to about 8". It has the welded tubing main gear.
Set up as it is the aircraft can only do wheel landings and they are at a relatively higher speed than my MK IIIC with straight leg, aluminum gear (but it couldn't do a full stall landing either). I can, with great care, get a three point wheel on landing out of the IIIX, but it takes only a little too much back pressure on the stick to touch down tail wheel first.
In flight the other thing I notice is that even with the lowest wing incidence setting the nose cone caves in under dynamic pressure. Somewhere along the trail of getting this aircraft rehabilitated I'll add some composite ribs to the nose cone to alleviate this. Builders might want to consider doing this as a preemptive measure before the windscreen and doors are in place and it is an easy reach to get to the inside of the nose cone.
Rick Girard
On Mon, Aug 22, 2011 at 7:45 AM, End User <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
| Quote: | I doubt the nose has a noticeable effect on landing. Not enough surface area.There is a difference at cruise though which is why they changed the wing incidence.
| Quote: | --> Kolb-List message posted by: "Mic" <miceire(at)gmail.com (miceire(at)gmail.com)>
Mic
— Carl Sagan
— W.B. Yeats
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Mike Welch
Posted: Mon Aug 22, 2011 6:39 am Post subject: Kolb MIIIX vs. Classic |
Rick, list guys,
When I was in the process of installing that Xtra nosecone, I anticipated that it would 'cave in'(depress). Even though I had it clecoed
firmly in place during my test fitting, I could easily depress the flat area with one finger.
Knowing it would act like you describe, I added four lengthwise reinforcement ribs. (1/4" wide X 3/4" tall X 24" long) This greatly
solved the problem, and I'm sure it won't deform under the airstream an excessive amount.
I also found I needed to do the same thing to the lower inside surface, too. It didn't give the impression it was going to deform as much as the
upper surface, but it certainly acted as though it would "some". I added the lengthwise ribs to it, too, and now they both are much more
rigid.
BTW, why did you elect to set the wings at 2.8 degrees, rather than 3.4 (which is what they told me to set them at)? If you had it to
do over, would you have aimed for 3.4, or do you think it would it have not made that much of a difference?
Mike Welch
On Aug 22, 2011, at 9:11 AM, Richard Girard wrote:
| Quote: | Although I am still fighting the good fight trying to get Ken Holle's Mk IIIX to not behave like a lawn dart, which, I believe, is particular to this airplane only and not Mk IIIX's in general, I do have one data point.
Rick Girard
rickofudall
Posted: Mon Aug 22, 2011 7:13 am Post subject: Kolb MIIIX vs. Classic |
Mike I moved them to the lower setting because I measured the lower surface of the fuselage and found that at 3.4 degrees it would still be flying at a negative angle in cruise flight. 2.8 degrees gets the fiberglass nose cone flying at a positive angle.
Rick
On Mon, Aug 22, 2011 at 9:37 AM, Michael Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: Michael Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)>
Rick, list guys,
rigid.
Mike Welch
> Rick Girard
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Mike Welch
Posted: Mon Aug 22, 2011 7:44 am Post subject: Kolb MIIIX vs. Classic |
Rick
Rick,
I guess you know what you mean, but it seems 'counter-intuitive' to me, how lowering the main wing's incidence raises the nose a bit.
I suppose we are speaking about NOT changing the hor. stabilizer's -4.8 setting, right? You're leaving it alone,yes, in both measuring points;
wing's at +2.8 deg & +3.4 deg?
If we're not changing the hor. stab, I don't quite see how the underside of the fuselage 'incidence' improves. Are you including adjusting the h. s. up and
down, when analyzing that fuselage's underside angle? Isn't the hor stab. the ONLY setting that affects the fuselage's incidence?
Are we leaving the hor. stab. set at the factory OEM setting? Thanks for the insights!
Mike Welch
Posted: Mon Aug 22, 2011 9:48 am Post subject: Kolb MIIIX vs. Classic |
You are flying the wing. All else is "incidental" baggage.
The more you can get everything else in line with that wing the
better off you are.
If ,in flight, the bottom of the fuselage is flat with the line of
flight then you have a
net down force on the nose. It will still fly (like mine) but a big
waste of energy.
The MkIII, like most planes in the same category, were originally
built to go 65 mph.
At that speed things like drag and extraneous forces aren't a big
deal. -any faster
and they become noticeable.
If you have a trailer with heavy springs just throw an extra 1000 lbs
of sandbags
in with your Kolb. I promise it will ride much smoother.
BB
On Aug 22, 2011, at 11:41 AM, Michael Welch wrote:
<mdnanwelch7(at)hotmail.com>
> Rick
Rick,
Mike Welch
rickofudall
Posted: Mon Aug 22, 2011 10:02 am Post subject: Kolb MIIIX vs. Classic |
Mike, I had to go dig out the last measurements I took. Relative to the engine mount the boom is at 7 degrees. That was fixed (set) by the cage weldment. The horizontal stabilizer is set right down the centerline of the boom.
Rick
On Mon, Aug 22, 2011 at 12:45 PM, End User <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
| Quote: | --> Kolb-List message posted by: End User <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
The more you can get everything else in line with that wing the better off you are.
If ,in flight, the bottom of the fuselage is flat with the line of flight then you have a
net down force on the nose. It will still fly (like mine) but a big waste of energy.
The MkIII, like most planes in the same category, were originally built to go 65 mph.
At that speed things like drag and extraneous forces aren't a big deal. -any faster
If you have a trailer with heavy springs just throw an extra 1000 lbs of sandbags
BB
Rick
Rick,
Mike Welch
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Mike Welch
Posted: Mon Aug 22, 2011 11:30 am Post subject: Kolb MIIIX vs. Classic |
Rick,
In my vigilant attempt to know as much as I can, especially when it comes to getting the wings set correctly,
I went out and measured my plane. I don't mean to kick a dead horse, while fun as that may be, your settings and readings
are quite a bit different than I would expect, and also different than my own digital readings., and from I understand,
also different than Kolb Co. suggests.
Here's what I just came up with on my plane just now;
1) engine mount zero, (factory established starting point)
2) boom tube is supposed to read -6.0, (mine does exactly!)
3) hor. stab. should be -4.8. (Mine reads either -4.8, or -4.2 at it's highest hole)
4) main wings are set at +3.4. ( I can get lots of readings, but they pretty much average out to +3.4)
These reading were discussed with Bryan Melborne, and he said they were EXACTLY what I should have. These figures
are virtually identical to an Xtra pilot who has recently started flying his plane.
To delve deeper into your concern about the incidence of the underside of the fuselage, I went ahead and made a couple
of additional readings while I had my digital level out. With my plane still propped up, in the -6.0 deg boom tube position,
the centerline, undeside of my fuselage, below where your legs would be, reads +.2 degrees. It has a very slight arch up toward the
front, but basically it's just a smidgeon positive (and that's with the tail way the heck up in the air!!!)
| Quote: | Then I measured the centerline of the bottom of the nosecone. +5.2 to + 5.3 degrees. It, too, has that rising arch, inline with the fuselage
arch.
Now, I am curious why your (Ken's plane) readings are so off from mine. Whether MkIII or MkIII Xtra, the underside of the
fuselage's are virtually unaltered from the original MkIII shape.
If I lower the tail end of the plane, back down to the floor, which I haven't done yet, but can, the underside of my fuselage
and nose cone are about 3-4 degs for the fuselage, and I'd bet 7-8 degrees for the nosecone.
From the angles you describe, including that -7.0 degree hor stabilizer position, no wonder the plane feels like a lawn dart.
I know I don't have the hundreds of hours flying the MkIII like you other guys have, but from the sound of things, that plane is rigged
to non-factory specs. IMO, unless I'm missing something.
| Mike Welch
| Quote: | On Aug 22, 2011, at 12:59 PM, Richard Girard wrote:
| Quote: | Mike, I had to go dig out the last measurements I took. Relative to the engine mount the boom is at 7 degrees. That was fixed (set) by the cage weldment. The horizontal stabilizer is set right down the centerline of the boom.
rickofudall
Posted: Mon Aug 22, 2011 11:57 am Post subject: Kolb MIIIX vs. Classic |
Mike, For one thing, you're reversing the effect of more negative angle of the horizontal stabilizer. Think of how a stabilator works, the more the leading edge is down, the more nose up on the wing.Two, the angle of the bottom of that portion of the fuselage forward of the struts WAS changed from that of the Mk III (C or whatever). It was decreased in an effort to get less separation on the bottom panel behind the struts.
Rick
On Mon, Aug 22, 2011 at 2:27 PM, Michael Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
Rick,
arch.
| Mike Welch
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Mike Welch
Posted: Mon Aug 22, 2011 12:17 pm Post subject: Kolb MIIIX vs. Classic |
On Aug 22, 2011, at 2:53 PM, Richard Girard wrote:
| Quote: | | Mike, For one thing, you're reversing the effect of more negative angle of the horizontal stabilizer. I'm finally getting what you are referring to. |
| Quote: | Think of how a stabilator works, the more the leading edge is down, the more nose up on the wing. Yes, I see where you are starting from in your statements.Two, the angle of the bottom of that portion of the fuselage forward of the struts WAS changed from that of the Mk III (C or whatever). It was decreased in an effort to get less separation on the bottom panel behind the struts. I wasn't aware of that. Oh.
Rick
Rick,
Now that I see where you were starting from in your desire to raise the nose, I understand. Thanks for taking the time to explain.
Mike W
pj.ladd(at)btinternet.com Guest
Posted: Tue Aug 23, 2011 1:27 am Post subject: Kolb MIIIX vs. Classic |
that it would 'cave in'(depress)>>
Mike,
you may have thought that but in practice it doesn`t. If you are happier
with the added ribs (and weight) that's fine but they not needed.. Someone
mentioned the aerodynamic properties of the nose. as far as is possible to
tell from flying the Xtra does generate a bit of lift from the nose if you
fly sideways or slip. It is just about noticeable and no problem.
Pat
Posted: Tue Aug 23, 2011 1:36 am Post subject: Kolb MIIIX vs. Classic |
Richard,
sounds as though you have a real pig there.
My Xtra does none of those things.
The nose does not collapse, It does not want to dive into the ground, It will threepoint perfectly well. Something very basic wrong by the sound of it.
My only grouse is the speed. With 2600 rpm from the Jabi I only get around 70 mph. I had expected 80 at least. I have no wheel spats which may have added a couple more mph but a) I am up against our MAUW rule and b) they fill up with mud in the winter.
Pat
Thom Riddle
Posted: Tue Aug 23, 2011 3:05 am Post subject: Kolb MIIIX vs. Classic |
..My only grouse is the speed. With 2600 rpm from the Jabi I only get around 70 mph. I had expected 80 at least...
Pat,
What prop do you have on your Jabiru. I believe the few Jab powered MkIIIX here in the US are running 58" dia. x Sensenich props with about 40" pitch (I think) and they report cruise speeds above 80 mph but at higher rpm than 2600. Which is about the same cruise speed I see on my Slingshot with 64" diameter x 32" pitch. Due to the much larger diameter on mine, I expect mine is a good bit louder, which is why I rarely cruise at over about 2650 rpm, frequently slower when I'm not in a hurry.
Thom in Buffalo
On Tue, Aug 23, 2011 at 5:33 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] Richard,
Pat
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
rickofudall
Posted: Tue Aug 23, 2011 10:06 am Post subject: Kolb MIIIX vs. Classic |
Pat, I'm well into the third of a three part article of all the things I've had to fix on this airplane. I believe I know what is causing the lawn dart syndrome and I'm well into the fix as I type. As soon as it's tested and the third part is finished, I'll publish them here. Probably under the heading, "For God's Sake, Don't Do This" or "How to Screw Up a Perfectly Good Airplane Without Really Trying".
Rick
On Tue, Aug 23, 2011 at 6:02 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
| Quote: | ...My only grouse is the speed. With 2600 rpm from the Jabi I only get around 70 mph. I had expected 80 at least...
Pat,
Thom in Buffalo
| Quote: | Richard,
Pat
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Thom Riddle
Posted: Tue Aug 23, 2011 10:54 am Post subject: Kolb MIIIX vs. Classic |
Rick,
I'm sure all Kolbers will be interested in your article. You should be able to get Sport Aviation (and/or others) to publish it for the benefit of all builders or would-be-builders.
Thom in Buffalo
On Tue, Aug 23, 2011 at 2:04 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Pat, I'm well into the third of a three part article of all the things I've had to fix on this airplane. I believe I know what is causing the lawn dart syndrome and I'm well into the fix as I type. As soon as it's tested and the third part is finished, I'll publish them here. Probably under the heading, "For God's Sake, Don't Do This" or "How to Screw Up a Perfectly Good Airplane Without Really Trying".
Rick
Pat,
Thom in Buffalo
| Quote: | Richard,
Pat
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Buffalo, NY (9G0)
- Anonymous |
Mic
Posted: Wed Aug 24, 2011 8:30 pm Post subject: Re: Kolb MIIIX vs. Classic |
Thank you one and all for your input and a very interesting discussion. It is much appreciated.
— Carl Sagan
— W.B. Yeats |
