Damaged Screw Heads when Attempting to Remove Fuel Tank
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
genie(at)swissmail.org
PostPosted: Sun Sep 11, 2011 1:00 pm    Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank Reply with quote
Due to a leaky starboard fuel tank I attempted to remove a panel on
the wing some of the screws were rather tight. This resulted in
damage to the screw heads.
How can I remove the damaged screws?
Once the panel is removed, what should I do to remove the fuel tank?
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
BARRY CHECK 6
PostPosted: Sun Sep 11, 2011 2:36 pm    Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank Reply with quote
On Sun, Sep 11, 2011 at 4:55 PM, George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)> wrote:
[quote] --> RV6-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
Due to a leaky starboard fuel tank I attempted to remove a panel on the wing some of the screws were rather tight. This resulted in damage to the screw heads.
Thanks.
George Nielsen
RV-6 PH-XGN
rget="_blank">http://www.matronics.com/Navigator?RV6-List
http://forums.matronics.com
le, List Admin.
BARRY CHECK 6
PostPosted: Sun Sep 11, 2011 2:47 pm    Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank Reply with quote
George:
Did you get an answer to your question?
Step 1:
Soak the screws with BP Blast.  It is a penetrating solution.
2 - Here you have a couple of options: a> Get a 10" long or greater SNAP-ON screwdriver.  NO Kitchen draw garbage... NOTHING MADE IN CHINA!  b> If you use a screwdriver with replaceable tips There is a special tip made by SNAP-ON that works GREAT also.
3 - If #2 fails then you have to get a DREMAL with a thin blade CUT-OFF BLADE and cut a slot head... YES you will probably cut into the skin.  AND you will still need a SNAP-ON quality COMMON, straight blade screwdriver.
For replacement work... DO NOT USE S/S screws.  Use high temper structural STEEL screws AND do not over tighten.  237.9% of the time people over tighten the screws, don't you be one of them.
Barry
Thanks.
George Nielsen
RV-6 PH-XGN
le, List Admin.
BARRY CHECK 6
PostPosted: Sun Sep 11, 2011 2:48 pm    Post subject: Damaged Screw Heads when Attempting to Remove Fuel Tank Reply with quote
OH! Ryan, you made a funny  ROTFLMAO!
Barry
On Sun, Sep 11, 2011 at 6:29 PM, Ryan Allen <johnryanallen(at)hotmail.com (johnryanallen(at)hotmail.com)> wrote:
[quote] use an easy out to remove the screws.
> Date: Sun, 11 Sep 2011 22:55:48 +0200
To: rv6-list(at)matronics.com (rv6-list(at)matronics.com)
From: genie(at)swissmail.org (genie(at)swissmail.org)
> Subject: Damaged Screw Heads when Attempting to Remove Fuel Tank
Thanks.
George Nielsen
RV-6 PH-XGN&g===
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
