Free RV Weight and balance program
greghale
PostPosted: Sat Oct 01, 2011 4:09 pm    Post subject: Free RV Weight and balance program Reply with quote
Hi Guys,
I have finally released the new RV weight and balance program. The program will work for all RV’s except for the RV3 and RV12. If there are any RV12 drivers that would like to have their aircraft included in the program, drop me an email and I will include it.
The program should be pretty straight forward on the operation, but I would suggest you also print the available 9 page Operation Manual on the web site. The beauty of the program is it will not only show you what your CG is at takeoff, but it will also tell you the CG at the arrival airport. Some owners may be surprised the change in the CG during your flight.
The program is absolutely free. This is my contribution to the RV community that I really enjoy.
You can go directly to this site to install the program. If you do get an error message trying to use the “Run” feature, try using the “Save” feature. That will download the file to your computer. You can then use that file to install the program.
http://nwacaptain.com/10weightandbalance.html
Greg….
www.nwacaptain.com
Greg Hale rv10 -- N210KH
www.nwacaptain.com
rvaitor(at)comcast.net
PostPosted: Sat Oct 01, 2011 5:14 pm    Post subject: Free RV Weight and balance program Reply with quote
This program is PC only, no web based version?
Shelby Smith
To: rv7-list(at)matronics.com
Sent: Saturday, October 1, 2011 7:09:51 PM
Subject: Free RV Weight and balance program
--> RV7-List message posted by: "greghale" <ghale5224(at)aol.com>
Hi Guys,
You can go directly to this site to install the program. If you do get an error message trying to use the “Run� feature, try using the “Save� feature. That will download the file to your computer. You can then use that file to install the program.
Greg….
www.nwacaptain.com
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=353732#353732
greghale
PostPosted: Sat Oct 01, 2011 6:55 pm    Post subject: Re: Free RV Weight and balance program Reply with quote
Yes--
Will only work on PC. It is possible Mac users may be able to get the program to operate on their computers.
Greg...
www.nwacaptain.com
