				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| raimo.toivio(at)rwm.fi Guest
				|  Posted: Tue Oct 18, 2011 6:01 am    Post subject: Heavy In-flight Vibration Riddle /The Solution /The Winner( |   |
				| Marcel, Frans and rest of you fine people
 My plan is to open and check the engine by
 professional during a winter delay.
 So far I think the piston # 3 is essential to
 check.
 Before that I will happily fly about 10 hrs. It
 runs so smoothly after replacing the spark plugs
 that I will not worry about possible damaged
 engine.
 Pls notice - the heavy  (infact very frightening
 and scary)  vibration and shaking was only quite
 momentous. I found quite soon a MAP & RPM
 combination which made sense. During the flight I
 tried couple of times if it will go better outside
 that combination but immediately came back.
 I was not worried my engine so much - that is only
 an engine  and w/o it a plane is still very well
 flyable. Instantly I worried about the engine
 fixing, structural things, engine separation and
 such things. I was happy I completed that Mod "an
 engine mounting frame strenghtening". I knew I
 have to make a soon decision to quit the engine
 and made a forced landing. When I managed to find
 a good power /rpm -selection, I was happy, relaxad
 a bit and went on flying. I was so satisfied that
 I did not try to find a solution and try magnetos
 A ja B separately. Maybe I thought -"the situation
 is good enough now - do not try to irritate it and
 dig any blood from my nose!".
 I have earlier forgot to mention one thing: when I
 tried to increase power by moving a power lever
 forward, I got significantly less power!
 That combination was somekind a sweet pot.
 The spark plug head was blue, you remember?
 I think it has been very hot. Maybe because it was
 totally short circuited. Then it was red glowing
 all time long - that is why I was talking about
 detonation. The mixture was maybe full time and
 totally exploded before the correct time. That is
 known to happen when for example one valve is red
 hot. If there has been detonation - there should
 also be some marks in the piston: after a hard
 load detonation the piston will be burned, a low
 load detonation can even split the piston.
 Also, I assume the coils are somehow connected
 together. I mean, a missfiring in one spark and in
 one cylinder, could it also disturb another one
 (spark /cylinder) ??? If so, that means more
 vibra.
 Anyway - this is quite an unusual think to happen.
 A Rotax Service Agent in Finland told me that
 there has only once before reported him about an
 inflight broken spark plug. That means about 1
 plug failures let us say in every 25.000 flight
 hours or less (under his thumb there are about 100
 Rotaxes, 10 years and +50 hrs /year / engine).
 So, obviously there are no reasons to worry about
 loosing a spark plug during a flight. We all are
 changing them every 100 hrs flight time, are not
 we?
 Raimo OH-XRT Finland, will be in Sicily in few
 hours
 -----Alkuperäinen viesti-----
 Sent: Monday, October 10, 2011 3:01 PM
 Subject: Re: Heavy In-flight
 <mz(at)cariama.nl>
 I have another thought on top: what will this have
 done to the crankshaft and/or piston rod and
 bearings?
 Should one be worried about increased tolerances,
 excessive wear a.s.o., especially having continued
 flight for an hour?
 I have made the same mental note that Frans has
 made, I too would not have expected vibrations to
 become so imminent by one failing spark plug.
 Thanks Raimo!
 Marcel
 (Europa Classic Tri-Gear PH-MZW)
 http://forums.matronics.com/viewtopic.php?p=354495#354495
 browse
 Un/Subscription,
 FAQ,
 Forums!
 List Admin.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| Remi Guerner
				|  Posted: Wed Oct 19, 2011 1:01 am    Post subject: Re: Heavy In-flight Vibration Riddle /The Solution /The Winn |   |
				| Hi Raimo,
As an engineer who has been working two decades for a spark plug company, I want to add a few thoughts about your engine problem:
 A misfiring spark plug, cannot cause detonation.
 A single misfiring spark plug on one cylinder cannot cause the high level of vibration you have experienced.
 There are only two cases where a spark plug can cause detonation: the first one is if you are using a spark plug with a too hot heat rating. In this case, the nose core and the center electrode of the spark plug becomes red hot and ignite the fuel mixture even without a spark. The second case is when the spark plug is not torqued enough, becomes loose so that the heat transfer from the shell to the cylinder head is limited, causing the spark plug to become very hot.  Both cases will cause preignition and possible detonation.
 I assume you were using the right spark plug type and that your blue spark plug was found to be tighten correctly. So in my opinion, the very hot blue spark plug you got was not the cause but the consequence of another phenomenon, probably preignition and/or detonation, caused by something else.
 The two main causes of detonation are: a too lean mixture and a too low octane fuel. This is were I would direct my investigation.
 Preignition and detonation may seriously damage all combustion chamber parts such as piston, rings, and valves.
 After such a problem I would ground the aircraft until the root cause is found, and I would carefully check the above parts for damage. Before removing the cylinder, I would perform a compression check and a boroscope inspection of the combustion chamber.
 Hope that helps.
 Remi Guerner
 F-PGKL
		| Back to top |  |
		| brian.davies(at)clara.co. Guest
				|  Posted: Wed Oct 19, 2011 3:24 am    Post subject: Heavy In-flight Vibration Riddle /The Solution /The Winner( |   |
				| Following on from Remi's post, it might be worth following the recent blog
on the Rotax Owners website.  A Rotax 912 owner suffered a partial fuel
 blockage to one carb that only showed itself under high power conditions-
 and then only intermittently.  In your case, if you have a partial fuel flow
 problem to one carb, reducing fuel flow by changing power settings could
 make the symptoms disappear.
 Worth checking?
 Brian Davies
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
