Heating issue in center console
Tim_Lewis(at)msm.umr.edu
PostPosted: Thu Jan 12, 2006 3:40 pm    Post subject: Heating issue in center console Reply with quote
>6. False floor - remember the heating issue in the center
> console? I spoke with the pilot who posted that data. Jeremy
> and I considered venting the center area, but couldn't find a
> good way to get the vented air out of the plane. Instead,
> several layers of insulation have been installed under the
> false floor. Hopefully this will do the job. I was told
> the heat was caused by the cowling air exit being located
> directly in the center of the fuselage. It is not an exhaust
> gas temperature issue.
Regarding Rick's item 6 (above), I'm having difficulty locating this
thread in the RV-10 list emails. Can anybody tell me the name of the
poster, and/or when the thread was discussed, or perhaps the title of
the thread?
Tim Lewis
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 790 hrs
RV-10 #40059 under construction
ron.mcgann(at)baesystems.
PostPosted: Thu Jan 12, 2006 3:58 pm    Post subject: Heating issue in center console Reply with quote
Tim,
Discussed on the VAF RV-10 forum.  Try the following link:
http://www.vansairforce.com/community/showthread.php?t=4187&highlight=tunnels
cheers
Ron
#187 fuse
LarryRosen(at)comcast.net
PostPosted: Thu Jan 12, 2006 6:59 pm    Post subject: Heating issue in center console Reply with quote
Tim,
The thread is on VansAirForce Forums in the RV-10 section titled "Hot
Tunnels"
This link should work
<http://www.vansairforce.com/community/showthread.php?t=4187>
Larry Rosen
the thread?
Tim Lewis
bhughes(at)qnsi.net
PostPosted: Fri Jan 13, 2006 6:49 am    Post subject: Heating issue in center console Reply with quote
A buddy of mine is near completion of a Lancair ES. His firewall is
composite and has a insulated, fire rated reflective blanked over it
between the engine and the firewall. This might help.
Bobby Hughes
(waiting on finish kit)
