Pre oiling new rebuild
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
Blue Sky
PostPosted: Mon Jan 16, 2012 11:12 am    Post subject: Pre oiling new rebuild Reply with quote
This is what I came up with(see photo) about $20 at the hardware store, clean, will hold a gallon, goes 40# plus on hand pump, hose attached. Should be useful for all kinds of engines that don't run often around my place.
Lyle
Hi,
I used an old gas cylinder (5 pounds ish!) with a schrader valve incorporated in the top of the cylinder and a hose connecting to the oil pressure outlet on the engine.  I used a small compressor to pressurise the cylinder pumping oil into all engine cavities.
All worked well.
Cheers
Peter
From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Lyle Fast
Sent: Thursday, 15 December 2011 10:43 AM
To: continental-list(at)matronics.com (continental-list(at)matronics.com)
Subject: RE: Pre oiling new rebuild
What did you use as a pressure source? I am starting a C85 in January.
Lyle
Date: Wed, 14 Dec 2011 12:15:08 -0500
Subject: Re: Continental-List: Pre oiling new rebuild
From: flyadive(at)gmail.com (flyadive(at)gmail.com)
J:
I use the OIL COOLER threads.
I want to do this but have not had the chance:  Remove one of the Oil Plugs on the front of the engine.  Pump the oil in at the Oil Cooler and SEE if the oil reaches the front of the engine.
As for the type of oil:  20W-50 Multi grade. Are yo breaking in the engine?  If so Philips makes a recommended 20W-50 Non-AD oil.
BUT!  Times they are a changing... Some Mfg. now recommend 20W-50 AD oil for break-in.    And that is the way I went. No Problem...  550+ Hrs since new.
Barry
  On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim(at)pro-ns.net (jezim(at)pro-ns.net)> wrote:
I have a fresh rebuilt 0-200 that I want to pressure oil before the first startup.  Where is the best place to hook the pressure line in? The oil filter, oil pressure sender, oil temp sender or one of the plugs in the front of the case? Also, how about 30 weight break-in oil this time of the year in Minnesota?  20 degrees F.    Thanks          jezim(at)pro-ns.net (jezim(at)pro-ns.net)
   _blank>www.aeroelectric.com/" target=_blank>www.buildersbooks.com=_blank>www.homebuilthelp.com=_blank>http://www.matronics.com/contributionList" target=_blank>http://www.matronics.com/Navigator?Continental-Listttp://forums.matronics.com=_blank>http://www.matronics.com/contribution
5
6
7
8
9
5
6
- The Matronics Continental-List Email Forum -
My passion for the landscape has lead me to the sky.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
