Continental-List Digest: 3 Msgs - 02/27/12
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
Jimz
PostPosted: Tue Feb 28, 2012 6:42 am    Post subject: Continental-List Digest: 3 Msgs - 02/27/12 Reply with quote
GM #1052943 Gasket Maker works. Aviable at you Chevy dealer.
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
dsleepy47
PostPosted: Tue Feb 28, 2012 8:44 am    Post subject: Continental-List Digest: 3 Msgs - 02/27/12 Reply with quote
If  your engine has a data plate you can go to http://www.genuinecontinental.aero/ and register for customer support. If your engine is still listed under a previous owner you will need to call but they are very helpful. Once you are registered you have online access to the current SIL's and SB's applicable to your engine. Look at the current revision of SIL 99, "CURRENT LISTING OF SEALANTS, LUBRICANTS, & ADHESIVES AUTHORIZED BY TCM.". There may be thousands of compounds and techniques that work but for things like this I see no advantage to deviating from OEM recommendations.
Deems
> Time: 03:09:28 PM PST US
> From: GLENN JOHNSON <gljno10(at)hotmail.com>
> Subject: O 200 CASE SEAL
> I have assembled my O 200 and was told by. Aircraft Specialty to use
> "Hylom
> ar AEROGRADE" and silk thread to put the case together. I now have
> several
> friends questioning if this is acceptable to use. I called Penn Yan Aero
> who has never heard of this. Anybody have any experience with this or shou
> ld I rebuild the engine before I start to fly it?
dsleepy47
N1491R
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
