Jim(at)JimVillani.com Guest
Posted: Wed Feb 29, 2012 8:13 am Post subject: RV 10 power plant question... |
Hey Guys…
What other versions of the IO 540 have been successfully installed in the 10?
Has anyone installed versions other than the IO 540 D4A5?
If so please advise…
I am about 6 months out until I need a power plant…
Thanks!!!
Jim Villani
Kit# 41084
Jim(at)JimVillani.com (Jim(at)JimVillani.com)
rene(at)felker.com Guest
Posted: Wed Feb 29, 2012 8:28 am Post subject: RV 10 power plant question... |
C4B5
Sent from my Verizon Wireless 4G LTE DROID
-----Original message-----
[quote]From: JimVillani <Jim(at)JimVillani.com>
Sent: Wed, Feb 29, 2012 09:11:59 MST
Subject: RV10-List: RV 10 power plant question...
<![endif]--> <![endif]-->
Hey Guys…
Thanks!!!
Jim Villani
Kit# 41084
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Wed Feb 29, 2012 8:44 am Post subject: Re: RV 10 power plant question... |
[quote="Jim(at)JimVillani.com"]Hey Guys…
Thanks!!!
Jim Villani
Kit# 41084
I installed a C4B5, as have many others. This engine was installed on Piper Aztec's and perhaps some other Piper's, but I don't know for sure about that. The engine mount ears from the Aztec will not fit the Van's engine mount, but the correct ears are available.
The C4B5 was rated at 250 HP on the Aztec by limiting max RPM to 2575. Lycoming says that it is identical to the D4A5 otherwise, so can be operated at 260HP/2700 RPM on the RV-10.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
davidsoutpost(at)comcast. Guest
Posted: Wed Feb 29, 2012 9:46 am Post subject: RV 10 power plant question... |
I am using an IO-540 V4A5. It came out of a 2001 Maule. The fuel servo is horizontal and more forward of the D4A5 if you use an elbow to convert it to horizontal induction. It also rides higher and tighter to the engine. This has been a challenge fitting the cowl and snorkel which require major surgery and fabrication but I am happy with the results so far. Its not flying yet so I have no idea how my home brew ram air system is going to work.
David Clifford
RV-10 Builder
Howell, MI
Sent: Wednesday, February 29, 2012 11:11:59 AM
Subject: RV 10 power plant question...
Hey Guys…
Thanks!!!
Jim Villani
Kit# 41084
tp://forums.matronics.com
rnewman(at)tcwtech.com Guest
Posted: Wed Feb 29, 2012 10:25 am Post subject: RV 10 power plant question... |
I got an O-540-E4B5 from a Cherokee 6-260 and added AFP fuel injection. fit perfectly without any modifications and used van’s baffle kit.
Bob Newman
N541RV
Sent: Wednesday, February 29, 2012 11:11 AM
Hey Guys…
Thanks!!!
Jim Villani
Kit# 41084
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Feb 29, 2012 1:43 pm Post subject: RV 10 power plant question... |
I have an IO-540-N1A5. 260hp
On Feb 29, 2012, at 9:11, "JimVillani" <Jim(at)JimVillani.com (Jim(at)JimVillani.com)> wrote:
[quote] <![endif]--> <![endif]-->
Hey Guys…
Thanks!!!
Jim Villani
Kit# 41084
cs.com
matronics.com/contribution
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
