heavyliftpilot
Posted: Sat Mar 03, 2012 6:15 am Post subject: IVO prop to trailing edge clearance |
Hey Guys....quick question (or two)....I have an IVO with the prop spacer. There is 5" prop clearance to the T/E.... I would like to move my 503 forward, but not sure how much clearance i should have. Reason? i bought this firestar II about 3 weeks ago, and found a 20 lb lead plate on the floor board (under the feet area)...and it's listed on the W/B sheet ((with a 220 lb pilot!!)) So, does this sound right to anyone?? i weighed the tail without the ballast and the tail weight increase from 63 to 68 lbs. The CG (with the ballast) is right at the aft limit. I would love to get rid of 20 lbs of dead weight (by moving other things forward, ie the 503) Any help? thanks, james
elleryweld(at)aol.com Guest
Posted: Sat Mar 03, 2012 10:42 am Post subject: IVO prop to trailing edge clearance |
if you have a battery on board you can move that to the front as I did in my old firestar
Ellery Batchelder Jr.
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sun Mar 04, 2012 5:25 am Post subject: Re: IVO prop to trailing edge clearance |
I don’t mean to be a smart-ass, but I do need to confirm this. When doing your W&B weight measurements to calculate CG, were you sitting in your Firestar II? I looked through my old notes and the tail weight was 42 lbs, but this is with a 447, and 190 lb pilot, but with tail boom shortened one foot from stock.
_________________ Jerry King |
Posted: Sun Mar 04, 2012 5:51 am Post subject: IVO prop to trailing edge clearance |
At 06:15 AM 3/3/12 -0800, you wrote:
James,
You need to run some prop to wing distance checkers.
See: http://jackbhart.com/firefly/firefly83.html
Jack B> Hart FF004
Winchester, IN
byoungplumbing(at)gmail.c Guest
Posted: Sun Mar 04, 2012 7:46 am Post subject: IVO prop to trailing edge clearance |
I donâ?Tt mean to be a smart-ass, but I do need to confirm this. When doing your W&B weight measurements to calculate CG, were you sitting in your Firestar II? I looked through my old notes and the tail weight was 42 lbs, but this is with a 447, and 190 lb pilot, but with tail boom shortened one foot from stock.
Jerry King
jerry that is a good thought, just to make sure all his ducks are in a row... it never hurts to make sure everyone is at the same starting point.
and to take it one step further, when doing the W&B measurements, in addition to him being in the plane,, is the plane set in the correct pitch attitude? without looking at the plans for the mkiii. it seems like it says the bottom of the wing should be at 8 deg positive incidence. in order to achieve this I had to have my tail wheel propped up on a 2 1/2 gal plastic bucket when I weighed everything, then subtracted the weight of the bucket.
boyd y
mkiii
