master swithch
rlallen1
PostPosted: Wed Feb 29, 2012 6:55 pm    Post subject: master swithch Reply with quote
I am currently working on my panel and wiring. I have a question on the master switch. From my reading of bob nuckolls I believe I need a 2-3. I am trying to confirm this and how to wire this up. I have the PP alternator. Do I run the field wire from the PP alt to the master switch? Do I need a separate switch for the alt and master?... please advise.
fyi, my set up is. PP alt, single battery, dual Pmags....if that matters.
Also, on the Pmags....for the P lead switch, those are just basic on/off switch rights...nothing fancy there..?
Ryan Allen
RV7 finishing stage
Ryan Allen
RV 7 in final stages
eddies
PostPosted: Tue Mar 06, 2012 12:02 pm    Post subject: Re: master swithch Reply with quote
Hi Ray,
I installed a separate master switch to activate the master relay and wired the PP alternator field to a separate switch with a light to indicate a failure mode.
The P leads on the Mags are just switched to ground as a function of the key switch for off or open circuit for on.
Cheers
Eddie
