napolin(at)me.com Guest
Posted: Wed Mar 14, 2012 8:42 am Post subject: FWF Fuel Line Torque Values |
I am wondering what the correct torque value for the FWF fuel and oil lines is. The Lycoming Overhaul Manual has fairly low torque values for "flexible hose or tube fittings " in the order of 30 to 35 in-lbs with corresponding values of over 100in-lb from Aeroquip and similar sources. Not sure which values to use.
Niko
rv10flyer(at)verizon.net Guest
Posted: Wed Mar 14, 2012 9:17 am Post subject: FWF Fuel Line Torque Values |
I used Aeroquip's settings for all lines. (brake, oil, fuel, etc)
Posted: Thu Mar 22, 2012 1:20 pm Post subject: FWF Fuel Line Torque Values |
Pascal
Thanks for the reply. I notice that the torque values for some of the fittings themselves such as fuel inlet to fuel servo are lower than what Aeroquip specifies for the hoses. I wonder if the intent is to have a lower torque onthe flexible hose fitting than the fitting to fuel servo so one doesnot inadvertantly loosen the fitting from the fuel servo while removing the flexible hose.
Nikolaos Napoli
